Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Jul 2010
    Brisbane
    143
    Default Industrial Betts motors... running hot !
    Hi .. Just finished the resto on my Fanmaster industrial fan..goes OK, just seems to run very hot... After a few minutes the motor is so hot you cannot hold your hand on it. What I find unusual is the lack of ventilation !!.. no holes in the front cover, and a cone cap on the other end..
    How do these Betts motors keep cool ?
    Ken.
    Aug 2011
    4,779
    Is it the bearings running hot?
    The reason I ask is that in once took apart a 3ph motor to convert to delta. It was in good condition, in fact I think it was new old stock.
    But when I pushed to two end back together and tightened the bolts that press the bearings back into the ends, I must have tightened them unevenly or not in correct order. The result was that the rotar bearings at each end were not seated perfectly in line. The motor still turned nicely by hand but when run for a few minutes without any load, the motor got hot. It was from the bearing getting warm.
    I took it apart and re-torqued the bolts gradually and evenly and it was fine.
    Lesson learned.
    Aug 2012
    Greenmount, W.A.
    70
    275
    The fan is supposed to keep the motor cool.
    Was it running before you started your work?
    Did you do any re-cabling of the supply?
    I take it the fan is single phase?
    If yes, does it have a centrifugal switch to open the "start" winding after it is running?
    If yes, does it open?
    Have you measured the current going into the fan?
    A picture of the terminals would help.
    Jul 2010
    Brisbane
    143
    Quote Originally Posted by A J in WA View Post
    When I was given it, it had an exploded start capacitor that i replaced with a new one..no re-cabling was done by me...
    10 Min ago I removed the back cover.. will take some pics and update soon as i can.
    Ken
    Nov 2010
    Frankston south
    102
    I have a Fanmaster with a Betts motor, although it is open at the front. I have a Paramount that is sealed and runs with no issue. Capacitor on mine is 4 microfarad
    Jul 2010
    Brisbane
    143
    Motor is single phase, 1.1 amp, 120 watts out..AOM Duty.
    Just cannot get any air flowing over the motor..
    Nov 2007
    melbourne australia
    3,228
    As AJ alluded to, the motor may have a centrifugal switch to engage a start winding. If that switch fails in the closed position the start winding will overheat very quickly. That would be worth investing I think. I doubt it’s lack of cooling airflow as the fan has been designed to run in that configuration.
    6,481
    Motors that small don't usually have a centrifugal switch !
    The windings usually have one end commoned to the neutral wire and the capacitor connected between the other ends. The live feed going to one end of the capacitor, depending upon direction.
    I don't think that the wiring is correct.
    It shouldn't make any difference if the ends of the windings are swapped over, the motor will run the other way.
    If there is a centrifugal switch it will be wired in series with the start winding.
    HTH.
    Nov 2007
    melbourne australia
    3,228
    True, but I can't think what else would cause the motor to get that hot. If no centrifugal switch and the capactor is new, perhaps it is wired correctly as you suggest.
    Nov 2016
    Gulfview Heights, Adelaide
    83
    Have you checked the motor windings to see if there is any damage to them?
    Maybe the old capacitor caused some damage somewhere when it exploded?
    You could try another start capacitor?
    Paul
    Nov 2010
    Frankston south
    102
    6,481
    Looking at the motor wiring the right hand picture, the mains input live wire, appears to be connected to the end of two windings, the ones coloured red and white.
    The mains neutral appears to be connected to the end of one winding and one side of the capacitor. There is another terminal marked (4) which doesn't seem to have any connection to it other than the blue wire.
    The capacitor is connected to the other wire with a white marker. This leaves a blue wire without a connection !
    It would be informative to know which wires are connected to which winding and if its is a dual voltage motor.
    The overheating could be that its wired for 110 volts and on a 240 volt circuit !
    Nov 2010
    Frankston south
    102
    6,481
    Hi Waxen,
    Thank you for the pictures, but it doesn't really help, the angle doesn't allow the wiring to be identified.
    However do you have four or five wires on yours, and is it a dual voltage motor ?
    Dual voltage is the only way I can account for five wires ! A single voltage motor without a centrifugal switch would have two windings and four wires, with a centrifugal switch there would be six connections.
  15. #15
    Nov 2007
    melbourne australia
    3,228
    That would certainly do it!
  1. Wiring a Betts Appliance motor
    By kenny_10 in forum ELECTRICALS
    Last Post: 22nd Oct 2017, 02:13 AM
  2. GMF Betts 12 Speed Drill Press Tidy Up
    By Burnsy in forum METALWORK GENERAL
    Last Post: 8th Dec 2014, 12:40 PM
  3. industrial junkyards
    Last Post: 29th Mar 2010, 05:03 AM
  4. Anyone here know Industrial Machinery Sales in SA?
    By hux in forum METALWORK GENERAL
    Last Post: 30th Apr 2007, 08:22 PM
