Results 1 to 3 of 3
    Feb 2009
    jilliby nsw
    111
    Default forward / reverse motor wiring
    Hello all, I have a single phase 240V reversible motor which I am fitting onto a Radial Drill to raise and lower the workhead. I also have a forward (position1)- Off - Reverse (position 2) drum switch with terminals numbered from 1 to 12. I can get the motor to run clockwise and anti clockwise but my issue is wiring the drum switch for the cross over wiring.
    Found this diagram on google, the upper and lower diagrams is the wiring for my motor. The diagram on the right i assume is the drum switch but I cant work out which terminals on my drum switch to use.
    drum switch 1.jpg drum switch 2.jpgThe drum switch has removable bridges joining terminal 1&3, 5&7, 9&11
    This is the terminal box on top of the motor
    Single Phase Electric Motor 240v 0.55 kW 0.75 HP 1400rpm 4 Pole IMB5 B5 Flange
    Can some kind person draw me a wiring diagram on how to connect all the wiring using the switch terminal numbers and the motor wiring terminals (Z2,U2,U1,V1......)
    Ive spent 2 days going around in circles trying to figure this out Heeelllpppp please
    6,477
    Hi Ian,
    Does this help ?
    Feb 2009
    jilliby nsw
    111
    Hi Ian,
    Does this help ?
    Could well do Baron, Ill have a look at it in depth tomorrow. Thanks for your input, cheers Ian
  1. Lathe motor runs in forward but not reverse
    By OLCDOG in forum METALWORK GENERAL
    Last Post: 24th Aug 2020, 12:54 AM
  2. reverse/ forward on mill
    By China in forum METALWORK GENERAL
    Last Post: 3rd Feb 2020, 09:30 PM
  3. Replies: 0
    Last Post: 25th Mar 2018, 06:58 PM
  4. Turning lathe motor from forward to reverse
    By Jim Ferrous in forum METALWORK GENERAL
    Last Post: 19th Sep 2013, 03:34 PM
  5. SOLD: 415v motor with forward reverse
    By Ch4iS in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 19th Apr 2012, 09:42 AM
