Results 1 to 7 of 7
Thread: Sieg mill x2L speed controller
9th Jan 2021, 07:18 PM #1New Member
- Jan 2021
- Tasmania
- 3
Has any body fitted a speed controller of ebay Chinese one to there x2L mill mine has be a problem and I don't want to put the same back on somthing of ebay 400w DC speed controller cheers
9th Jan 2021, 07:59 PM #2
9th Jan 2021, 08:15 PM #3New Member
- Jan 2021
- Tasmania
- 3
9th Jan 2021, 08:21 PM #4New Member
- Jan 2021
- Tasmania
- 3
9th Jan 2021, 08:28 PM #5
Hi Tim,
You really need to have a look at the machine manual that you got with your machine to identify which kind of motor drive system that you have. I know that both motor systems were fitted to the Seig machines.
The mention of stopping and starting suggests that you have an older machine with a brushed motor !
If this is the case then I would be looking at replacing the motor carbon brushes, which is a very common point of the problems that you describe. The other but more unlikely issue is the speed control potentiometer itself. They do wear and become intermittent, replacing one is quite straightforward if that is the case.Best Regards:
9th Jan 2021, 08:32 PM #6
Tim, It seems that you posted the answer to my question whilst I was still typing
In that case the first step is to examine the carbon brushes and replace them if the are worn.Best Regards:
10th Jan 2021, 09:28 AM #7Senior Member
- Oct 2009
- Upwey VIC
- 187
Tim, I had the same problem once on my X2. It was the speed control pot. I bit of a play with the shaft allowed the innards to firmly connect. Problem solved. Check that there is no swarf in the motor control boxes also.
MC-60 treadmill speed controller (controller needs a load ?)
By DenJon in forum ELECTRICALSReplies: 5Last Post: 1st Dec 2019, 07:49 PM -
Motor Speed Controller
By barkersegg in forum ELECTRICALSReplies: 15Last Post: 23rd Aug 2018, 08:49 AM -
Sieg KX3 CNC Mill
By da9jeff in forum CNC ForumReplies: 2Last Post: 2nd Oct 2017, 12:42 PM -
Mill motor controller !
By BaronJ in forum METALWORK GENERALReplies: 4Last Post: 14th Jul 2017, 01:51 AM -
Variable speed motor and controller
By Jim Ferrous in forum METALWORK GENERALReplies: 5Last Post: 24th Sep 2013, 03:03 PM
