Results 91 to 96 of 96
12th Sep 2021, 10:25 PM #91Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
This modification should improve the response time of the tachometer shown in the video(Post 85).
I replaced the single magnet with 6 smaller magnets mounted in a piece of pvc conduit. I am waiting on a new panel meter to arrive, this one will be adjustable for the number of pulses per revolution.
20th Sep 2021, 10:26 PM #92Most Valued Member
- 2,673
3-wire FWD/STOP control
Any chance you could explain how you set it up?
I've looked at the manual and looks like possibly this setup (I haven't tested though and have never done a 3-wire setup before):
X1 ==> 3 (3 wire run control)
X2 ==> 1 (forward running)
The NO button for run goes between X1 and X2, and the NC for stop goes between X2 and ground??
21st Sep 2021, 06:41 PM #93Golden Member
- Sep 2008
- 838
Hi Steve, I used X1 for Forward Running switch (NO) and X2 for stop switch (NC) and the com wire is bridged between the 2 switches (similar to Fig 2 on page 37). These are the settings I used and although they do not make a lot of sense, they work: P0.02 - 1, P3.01 - 1, P3.02 - 3, P3.08 - 2. I also moved Jumper 6 to lower position although that may not have been necessary.
22nd Sep 2021, 06:40 PM #94Most Valued Member
- 2,673
Ecogoo 1ph 220v to 3ph 400v inverter - experiences
Thanks Techo!!
I can confirm those settings work and the jumper change NOT required.
For anyone playing along at home, I’d suggest you configure the VFD before hooking up the switches, or to set the P0.02 setting LAST.
P0.02 ==> 1 sets control to the terminals and you can no longer start/stop from the keypad.
if you set that parameter before configuring the P3 parameters and have the switches connected you can end up with the motor running - and unable to stop it without turning off the supply to the VFD.
I also do my testing with the freq set down to about 10hz and the ramp up time about 4sec.
That way if (when) you run the motor unintentionally (or in the wrong direction) it’s not such a drama.
24th Oct 2021, 10:11 AM #95Golden Member
- Sep 2008
- 838
Just a follow up on fitting extra magnets (post 91) to improve the response time of the digital panel mount tachometer. With the 6 magnets fitted it updates much faster, as opposed to the single magnet (video in post 85) but obviously the reading is 6 times too fast and the actual Tacho is not adjustable for pulses per revolution.
https://youtu.be/C5DED_5VeEY
I fitted another Tacho with adjustable divider and it is working perfectly now. Does anyone know how to get rid of the decimal point, I don't need to know the speed down to tenths of revolutions per minute?
https://youtu.be/Q6eozL64TSA
24th Oct 2021, 06:49 PM #96
Any experiences with H&F granite surface plate ?
By StrayAlien in forum METALWORK GENERALReplies: 20Last Post: 5th Nov 2020, 08:59 PM -
Experiences About Frost Brand tools.T
By familyguy in forum METALWORK GENERALReplies: 17Last Post: 5th Aug 2018, 01:30 PM -
Treadmill motor controller - will 220v scr be ok? Inductors needed?
By j3dprints in forum METALWORK GENERALReplies: 10Last Post: 1st Jan 2018, 11:10 PM -
240v to 220v cheap solution? For china stuff
By j3dprints in forum ELECTRICALSReplies: 10Last Post: 21st Dec 2017, 11:41 PM -
Small Lathe Experiences
By Blu_Rock in forum METALWORK GENERALReplies: 48Last Post: 11th Nov 2008, 10:29 PM
