Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Is/was the motor running at 50Hz?
    If via a VFD, it may be that the air flow is not enough (I think air flow is related to rpm2). Just thinking that if the air flow was not enough to blow the heat way, the housing would get toasty and then melt the fan, lessening air flow more (and repeat).
  2. #17
    6,439
    I've seen something similar where the fan securing screw allowed the fan to migrate down the shaft to sit on top of the motor case, the heat melting the no longer rotating fan. I've also seen this with a metal cast fan, sat on top of the motor case.
    Those class "F" insulation motors are usually category "CR" continuously rated with a max temperature spec on the rating plate.
  3. #18
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Motor running at what ever the house supply is, no VFD.
  4. #19
    Dec 2013
    56
    1,416
    Sounds strange, I'd put a new fan on it and keep a check on it often.
    Do you have a digital thermometer to check it? There only cheap on eBay.
    I sometimes get some weird noises when I start mine or when it's running, I dont think there the best quality motor, one day I'll get around to fitting the new VFD motor I bought, lol
    Using Tapatalk
  5. #20
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Hello Dave, just waiting on a fan to arrive, not sure as to how long this issue had been present, noticed today that cast iron dust had settled on the surface of the melted remains of the fan and unable to remove it, so would appear that it possibly had been just sitting on top of motor for a while.
    No thermometer, but in past have just used my hand on the motor fins after prolonged use, normally hot.
    Tried the motor again this morning everything worked as normal with no unusual noises ( only ran for about 10 secs in for/Rev, test will be after the fan goes on.
  6. #21
    Dec 2013
    56
    1,416
    Hopefully it's like you said and just cracked and worked it's way off
    Using Tapatalk
  7. #22
    Jun 2007
    sydney ( st marys )
    64
    4,887
    New fan and hub fitted, motor seems okay at present.
  8. #23
    Nov 2007
    melbourne australia
    3,228
    The motor is 1.5kw, 240 volt vertical flange mount, the motor is 17 yrs old.
    Hi Peter,
    Sorry I'm late to the party. If it's a single phase motor, maybe the centrifugal start switch is fused closed and the start winding is continuously energised? I cooked my table saw motor that way. Ordinarily the start winding would eventually burn out, but perhaps a well made motor would just get very hot as yours obviously has.
  9. #24
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Hello Chris,
    I know very little about electrics but if that switch was locked on would I be able to get reverse?
  10. #25
    Nov 2007
    melbourne australia
    3,228
    I'm pretty sure you would. The reverse switch reverses the polarity of the start winding. The centrifugal switch disconnects the start winding when the motor is up to speed.
    Apparently a shorted capacitor can result in the motor overheating too.
    It would be worth taking it to a motor rewinder for a quick checkup.
  11. #26
    Oct 2015
    melbourne
    473
    You should be able to hear the centrifugal switch open and close as the motor starts and stops.
    Not loud but should be distinct..
  12. #27
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Not sure if I hear it starting but definitely when stopping.
  13. #28
    6,439
    The centrifugal switch on the lathe is very quiet when starting up but makes a loud clunk when stopping. Compared to the one on my grinder which you can barely hear either way.
  14. #29
    Jun 2007
    sydney ( st marys )
    64
    4,887
    It has been a month since the new fan and hub was fitted, machine has been used for around 50 hours with no issues, maybe I got lucky.
    Thank you for the replies.
  1. Tig water cooling
    By eskimo in forum WELDING
    Last Post: 16th Feb 2018, 08:15 AM
  2. Large plastic chopping board at ALDI - good plastic stock
    By pippin88 in forum METALWORK GENERAL
    Last Post: 3rd Jul 2017, 10:24 PM
  3. Cooling down a mini-mill motor
    By Jors in forum METALWORK GENERAL
    Last Post: 15th Jan 2013, 09:10 AM
  4. flood cooling
    By tanii51 in forum METALWORK GENERAL
    Last Post: 5th Mar 2010, 09:18 PM
  5. Cooling while cutting
    Last Post: 7th Mar 2007, 12:42 AM
