Results 1 to 6 of 6
30th Sep 2020, 04:33 PM #1Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
Beaver Milling Machine Motor question.
Would I be correct in saying that this motor cannot be easily converted to run on a 240V single phase input VFD and still produce 3HP?
30th Sep 2020, 05:35 PM #2Most Valued Member
I think you may be correct given its a 400 - 440v delta wound motor.
Ultimately you really would prefer to see that nameplate say 400 - 440V star. That way you can reconfigure it to run 240V delta and still put out the required HP.
However, if the price is right then perhaps it is worth your while to look for another motor?
30th Sep 2020, 06:11 PM #3
Hi Lex, Guys,
You would need a 230 volt input VFD with a 420 Volt three phase output to use that motor at its full potential !Best Regards:
30th Sep 2020, 07:08 PM #4Golden Member
- Sep 2008
- 831
Thanks Simon and Baron, that's what I thought, unfortunately it is a custom made flange mount specific to the machine.
Lex.
30th Sep 2020, 09:17 PM #5
Hi Lex,
I'm a little confused ! Is that the original Beaver mill Motor ? Or is it one you are thinking of obtaining.
Brooks motors made many different motors but tended to use common castings for the end frames for the particular sizes. So a 3 Hp single phase motor would have the same frame casting used for all the voltage variants. Only the stator frame internally would be different and of course the rotor.
Now having said that they did make motors to suit specific customer requirements, such as different end frames used for face mountings and the like.
So its quite possible that a standard 3 Hp Brooks motor of a different voltage could have the end frame swapped.Best Regards:
1st Oct 2020, 11:00 AM #6Golden Member
- Sep 2008
- 831
It is the original motor Baron, here's a picture of the flange mount:
Electric Motor Question
By Oldneweng in forum GENERAL DISCUSSION / OFF TOPICReplies: 8Last Post: 21st Jun 2016, 12:53 PM -
Electric motor question
By BobL in forum METALWORK GENERALReplies: 9Last Post: 2nd Feb 2016, 09:27 AM -
3 phase motor question
By Com_VC in forum METALWORK GENERALReplies: 17Last Post: 10th Oct 2012, 12:29 AM -
vfd question for my lathe motor
By tanii51 in forum METALWORK GENERALReplies: 5Last Post: 27th Jul 2011, 09:40 PM -
Single Phase Motor Question
By Glenhuon in forum METALWORK GENERALReplies: 3Last Post: 22nd Oct 2009, 10:49 AM
