Results 31 to 45 of 51
8th Jan 2022, 09:01 AM #31Member: Blue and white apron brigade
In 2018 I posted some HP output tests on a DC treadmill motor powered by a simple triac and rectifier.
For anyone interested to see how they perform (ie not very well) have a look here.
https://www.woodworkforums.com/f271/...ormance-223851
It also describes what happens if you crank the V up too high.
8th Jan 2022, 11:59 AM #32Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
8th Jan 2022, 02:56 PM #33Senior Member
- Aug 2021
- 46
- 117
Interesting thought. I hadn't heard of this phenomena either but I've removed plenty of DC brushed motor armatures, done maintenance and returned them, so I wonder if I've been damaging them!
Bob, thanks for the link to your tests, looks like quite a comprehensive write-up. I have only skimmed so far but will have a proper look later. I wonder if a triac chopper type system with some decent filtering might have better results than the cheap Chinese dimmer + Bridge Rec. I will have access to a decent workshop with good test equipment in just over a week so I might be able to follow through on some of these ideas soon, will see how we go.
I couldn't find the open source controller I thought I had seen but there is an open source coding repository for some Arduino code designed for treadmill use but that might be the end of the story on that one. The more I think about this the more I think I will try a DIY PWM controller, maybe a simple version first. I probably won't publish every detail as I know that in the wrong hands electricity can have lethal consequences. But I might write little summaries of what I am up to.
I have read in many places (Just general comments but no scientific explanation) that the PWM method allows full torque (or close to it) at all speeds. I assume this is something to do with the full voltage pulses of the PWM waveform. I hope that this is the case, some basic tests with 36V pure DC worth of Ryobi 1.5AH batteries showed pretty miserable subjective torque with the claimed 2HP motor. I didn't do proper torque tests, but it felt pretty weak when I slowed the flywheel with my hand.
8th Jan 2022, 08:58 PM #34Member: Blue and white apron brigade
Most likely - I was just debunking the claims made on more than one you tube vids about how the cheap chinese dimmer and rectifier was all that was needed.
8th Jan 2022, 09:19 PM #35
Hi Nigel, Guys,
Basically yes ! Heat doesn't do them any good either, fortunately the motor rarely gets that hot, usually the armature adhesives and soldering melt first.
This is because the heat that they produce can only escape via the motor shaft and the bearings. The difference in temperature between the armature and the case can get to be as much as 70 to 100 degrees C.Best Regards:
8th Jan 2022, 09:32 PM #36
With regard to SCR/Triac plus rectifier configuration, part of the problem is the speed of the rectifier !
A perfect rectifier switches fast enough to prevent anything other than one polarity through. In practice a small amount of reverse voltage gets through first before the rectifier becomes fully conducting. This creates a ripple voltage that is quite hard to remove. Large capacitors help but don't completely remove it. As the load increases the ripple gets worse.Best Regards:
9th Jan 2022, 11:43 PM #37Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
PWM will provide near full torque (in theory full, in practice you have losses and kinetics to overcome). There’s no real science behind it, you apply a pulse of DC at the motors rated voltage, it sucks full current which provides full torque.
Making a 180V motor run on a couple of cordless tool batteries doesn’t prove much other than it rotates when DC is applied. Running it at 1/6th of its input voltage won’t produce any useable torque.
10th Jan 2022, 11:41 AM #38Senior Member
- Apr 2018
- 168
Ive been using these boards for last 25 odd years for DC motor control. Very versatile as just change load resistor to suit HP of dc motor. Very reliable with excellent speed control via voltage or 5K pot.
https://www.kb-controls.com/product.sc?productId=3
20th Jan 2022, 02:47 AM #39Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I see a few different controller options on Aliexpress for running treadmill motors, I've link a couple for more knowledgeable people to look over and give their thoughts.
https://www.aliexpress.com/item/1005...79882947%22%7D
https://www.aliexpress.com/item/3273...rch-mainSearch
https://www.aliexpress.com/item/4001...rch-mainSearch
I would happily spend $70-$80 for a controller to make good use of the 180V DC motors I have laying around
20th Jan 2022, 12:10 PM #40Golden Member
- Dec 2007
- 574
I'm with Sparksy on this one - I have the same Kbic controller for my drill press motor - very happy with it, a local purchase on Ebay around $70 from a buyer saying it was from a project that never got off the ground - if was looking for a controller from Aliexpress I'd be going with this one
The only possible concern to me would be the input voltage of 220V, my mains sits on 242V - 243V and can at times hit 246V
20th Jan 2022, 12:32 PM #41Member: Blue and white apron brigade
20th Jan 2022, 06:58 PM #42Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I notice it doesn’t have the large capacitor/s found on some of the other boards, I have no idea if that matters at all?
It would be nice to finally have a working, economical solution to the treadmill motor problem i.e.
A common generic replacement PWM board, a potentiometer of correct value for the board and a wiring diagram.
one thought I had would be to add an On/Off/On style switch between the board and motor which could be wired to reverse polarity at the flick of a switch, providing these motors are capable of running in reverse.
from what I can tell there appears to be 4 main types of boards on AliExpress, a single capacitor board with either 2 or 3 wire speed sensor, and a twin capacitor board also with 2 or 3 wire speed sensor.
I guess the speed sensor depends on the type of motor you have?
20th Jan 2022, 08:57 PM #43
Just a note to warn that all these controllers do not provide any isolation from the mains voltage supply ! That includes the controllers from inside the donor treadmill.
For safety the motor must be earthed and the controller board placed in an insulated plastic or an earthed metal box.Best Regards:
22nd Jan 2022, 11:55 AM #44Senior Member
- Aug 2021
- 46
- 117
Absolutely true for the treadmill controllers.
Haven't looked at the suggested controllers yet, but if they have a speed sensor and a feedback loop then that might indicate a pretty good solution, the absence of a capacitor on one of them is a bit weird.
Interesting problem to have, this one.
22nd Jan 2022, 09:01 PM #45
FREE - variable speed 1hp motor from treadmill. Brisbane south side. PU only.
By GDD in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 22nd Aug 2020, 08:43 AM -
Twin belt belt grinder.
By onanonanon in forum METALWORK GENERALReplies: 6Last Post: 18th May 2018, 03:52 PM -
Treadmill motor controller - will 220v scr be ok? Inductors needed?
By j3dprints in forum METALWORK GENERALReplies: 10Last Post: 1st Jan 2018, 11:10 PM -
Treadmill motor swap flywheel reworked.
By aametalmaster in forum METALWORK GENERALReplies: 3Last Post: 3rd Mar 2014, 09:35 PM -
Treadmill donkey on a Nuttall belt driven spindle?
By fuglee1 in forum METALWORK GENERALReplies: 2Last Post: 28th Dec 2013, 04:50 AM
