Results 16 to 30 of 35
Thread: VFD Remote Switch Panel
15th Sep 2020, 04:39 PM #16Member: Blue and white apron brigade
15th Sep 2020, 05:05 PM #17Most Valued Member
I keep thinking I should make some sort of draw-bar style retainer for my 4 jaw. More often than not I don’t need the stock to go into the bore of the 4 jaw chuck. I only occasionally need the bore of the 4 jaw when I’m turning long square stock.
15th Sep 2020, 06:03 PM #18Golden Member
- May 2020
- Willowbank QLD
- 535
Danshell
I have a connon motor VFD and I am wearing through the stop pad on the unit. I was thinking of seeing if I could buy a new pad. Now I have seen your setup that is what I want. Would you be able to post here or send the circuit diagram and such as a how to. I allready have the same tacho set up. My 11x24 lathe has forward and reverse with no screw on chuck.
15th Sep 2020, 06:57 PM #19Member: Blue and white apron brigade
15th Sep 2020, 07:24 PM #20Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
15th Sep 2020, 08:02 PM #21Senior Member
- Oct 2019
- Tasmania
- 53
- 150
No problems Steve and Lex. I’m at work tonight but tomorrow I’ll post up the info so if anyone else wants to do a similar thing they can see it also.
16th Sep 2020, 12:17 PM #22Senior Member
- Oct 2019
- Tasmania
- 53
- 150
Here are the instructions to do what I did to my Lathes remote panel.
A few little disclaimers.....I was helped out by a gentleman online with these instructions (although I have edited them to show what I did exactly) the diagram he drew said on it not to distribute or post online, he afterwards told me to use them to help others when requested. However the diagram and instructions are now altered to show what I ended up doing, they are not the actual ones I was given.
Also, do this at your own risk. All of this worked for me with no problems but thats not say you wont have issues, so use this guide with caution.
And finally, I do not not know the legalities of wiring a VFD for remote switches in Australia. Even though the remote switching is low voltage, you are placing wires in an area that has high voltage wiring nearby, so again, do so at your own risk or get a qualified electrician to do it. Obviously I unplugged all power from the VFD before proceeding with any wiring!!
WIRING DIAGRAM FOR THE LOW VOLTAGE REMOTE SWITCHES
PHOTO OF MY REMOTE PANEL AGAIN FOR REFERENCE
The main power ON/OFF switch that is lit up in the photo is switching the 240v AC so I can not show a wiring diagram for this. This is a job for a qualified electrician The reason I did this is so I can leave the Lathe plugged in at the power point and switched on and I can control it at the main panel.
I am going to supply links to what I bought in regards to the hardware, but please note I am a tight so I buy things on ebay and sometimes from China. Postage took forever in some cases as you can imagine atm but thats the price a cheapskate like me has to pay!
240v Green ON/OFF Switch with light
https://www.ebay.com.au/itm/22mm-Ill...A/223044624237
Emergency Stop Button (PLEASE NOTE THE Normally Open or Normally closed configuration as per wiring diagram)
https://www.ebay.com.au/itm/Emergenc...e/273615978725
Green and Red Forward/Stop/Reverse and black Jog Momentary switches (PLEASE NOTE THE Normally Open or Normally closed configuration as per wiring diagram)
https://www.ebay.com.au/itm/22mm-Pus...N/132779231926
Digital Tacho
https://www.ebay.com.au/itm/Red-4-Di...U/174352016181
Shielded Wire
https://www.ebay.com.au/itm/SHIELDED...N/114160435032
10K Potentiometer
https://www.jaycar.com.au/10k-ohm-li...meter/p/RP7510
Potentiometer Dial
https://www.jaycar.com.au/numbered-k...-1-10/p/HK7549
Mini Breaking Switch (again please note to the on/on configuration)
https://www.jaycar.com.au/spdt-minia...r-tag/p/ST0335
Once wired, here is how I programmed it all. This works for the Folin BD600 Series VFD but it may help others that use other VFD's??
When I was programming it I had some difficulties getting it to bring up the parameters required in the case of the forward/stop/reverse switches. I had to factory reset a couple of times and in the end I think I may have done them first and the terminal control operation after those, or perhaps it was the other way around......arrgh....but anyway you will figure it out, just try one way and if that doesnt work go the other way!!
Now the gent that helped me with this also recommended I do this learning thing outlined below. I have not done it yet. The electrician at work said its not needed but doesnt hurt either way, so again choices are all yours.
Please note these are the parameters I gave my motor. Some of you may not want to run your motor up to 75hz, so please do your own research and or call your supplier and ask.
Now just a quick explanation as to how to actually program these figures into the VFD..........here is an example for the Reverse/Stop/Forward functions,,,
Press "PRGM" > use arrows to go to F05
Press "FUNC" > keep at F05.00
Press "FUNC" > Leave 1 at 1
Press "FUNC" > Press "PRGM" twice to go out
Press "FUNC" > use arrows to go to F05.01
Press "FUNC" > Change 4 to 3 (4 should be the default display)
Press "FUNC" > use arrows to go to F05.02
Press "FUNC" > Change 9 to 2 (9 should be the default display)
That is a basic tutorial. As you get into programming your VFD you will see that it is quite simple and when doing repetative steps some of the steps I have described above are skipped....you'll understand when you start messing with it.
I hope that helps and if you have any issues yell out and Ill see if I can help. I am not an expert at all. I am simply a person like you, who asked for help, received it and now I am passing on the knowledge that i was given.
16th Sep 2020, 12:25 PM #23Senior Member
- Oct 2019
- Tasmania
- 53
- 150
Whoops, I forgot the wiring diagram for the digital tacho.
Here is a screen grab from a youtube video I watched that helped me to wire mine up.
https://youtu.be/j59UjV0-ptE
The only thing I will mention is that high voltage wiring interfered with the tacho wiring and made it very erratic. I had to shield the tacho wiring to get it to work properly. Took me bloody hours of stuffing around with it before I realised what was causing the problem.
20th Sep 2020, 07:51 PM #24Member
- May 2018
- Cairns, Qld.
- 70
VFD Panel - South Bend
Hello Danshell & other responders to this thread. I'm rebuilding a Sheraton 9C lathe lately as a shed project. This machine is pretty much a copy of a basic South Bend 9 lathe as I understand it. It won't be my primary machine.
I'm right now at the point of working on the antiquated - looking reduction drive assembly, i.e. the heavy cast-iron mount, yoke & pulleys, plus the need for a new single phase motor of 0.55 Kw. or less, which is going to cost about $200 locally anyway.
Would you care to share the type, size & manufacturers of the VFD & 3-phase drive motor that you used? I note that your supplier is in Melbourne. I'd no doubt look for a supplier closer to me in FNQ.
I guess the main question at the end of it all is, "Is it worth it" ??
Many thanks....
H614
20th Sep 2020, 09:41 PM #25Member: Blue and white apron brigade
20th Sep 2020, 10:07 PM #26
Hi H614,
If you have a browse around your local scrap yard you probably be able to find a suitable motor. If you do check that the scrappy will take it back and let you pick another one if its bad. I tend to go for sized up shower pump motors. Usually its only the hot side pump that is sized up and the motor is OK. However I'm told that shower pumps are quite rare in AU. Which is a pity because almost all the ones I've picked up are around 1/2 Hp, 660 to 700 watts.Best Regards:
21st Sep 2020, 11:28 AM #27Senior Member
- Oct 2019
- Tasmania
- 53
- 150
The VFD and Motor as you know was purchased from Conon Motor in Vic, their shipping is fast and very reasonable (for the most part it is included in the purchase price). The VFD is branded Home_ZHEJIANG NEW FOLINN ELECTRIC CO.,LTD it is the BD600 series.
I have a photo of the plate on the motor that gives you the manufacturer and specs of that. The VFD is rated to for use on the motors HP rating.
Is it worth it? Well for me it was. The whole set up, including the remote panel switches cost less than $400 and of course it makes the old cone pulley and step up pulley redundant as I can control the speed electronically. It can be done for half that price if you shop around on ebay. I paid a premium as I wanted to make sure the VFD and motor were compatible and it came from a reputable importer.
I have a little shaper here that I am about to start restoring and I may do that one on the cheap and see how it compares.
Hi Bob The VFD has a 24VDC outlet.
21st Sep 2020, 12:42 PM #28Member: Blue and white apron brigade
Thanks. It's interesting that the VFD should upset the Tacho. I have 4 such tachos on machines in my shed, 3 are powered via VFDs and one by a simple 12V wall wart adapter and have no problems.
How far away is the VFD from the tacho?
I've had VFD noise issues with auxiliary electronics (Arduino micro processors) on my coffee machine and on my pressure monitoring system (PMS) on my dust collector. The coffee machine issue ws sort of sorted but still have probs with the PMS.
21st Sep 2020, 01:44 PM #29Senior Member
- Oct 2019
- Tasmania
- 53
- 150
21st Sep 2020, 07:03 PM #30Member
- May 2018
- Cairns, Qld.
- 70
VFD panel
Hi Danshell & Baron J. Many thanks for the responses.
I had a look at Conon's website; very interesting! The 0.55Kw 3 ph.motor that you show & the BD600 VFD to drive it (F1-H100S20007BXO, is that correct??) are a not unreasonable price, bearing Danshell's comment about the certainty of them working together.
Would you be able to photograph the new motor & belt drive, & VFD main box installation on your SB lathe & post them here?
Perhaps I should stop further work on the original step-down arrangements until I've weighed this up further?
Rgds. H614
Vfd remote switches.
By eskimo in forum ELECTRICALSReplies: 9Last Post: 8th Jun 2019, 11:22 AM -
Switch Enclosure- Switch Position Identification.
By Anorak Bob in forum METALWORK GENERALReplies: 17Last Post: 19th Jul 2016, 11:00 AM -
VFD Remote Cable
By Oldneweng in forum METALWORK GENERALReplies: 18Last Post: 14th May 2014, 07:39 AM -
Switch Panel Graphics for Dummies
By Bryan in forum METALWORK GENERALReplies: 8Last Post: 19th Apr 2011, 11:01 PM -
VSD Remote Control Panel Questions
By markjaffa in forum METALWORK GENERALReplies: 28Last Post: 20th Apr 2010, 05:15 PM
