Page 4 of 4 FirstFirst 1234
Results 46 to 54 of 54
Thread: VFD outputs
  1. #46
    Mar 2011
    Southern Flinders Ranges
    1,555
    Wire the motor direct to the VFD with all the remote start and contactors removed. If it still won’t start in delta then you have a problem with windings, if it does the problem is with the additional circuitry. Reintroduce one thing at a time until the fault is located.
  2. #47
    Mar 2014
    North Queensland
    38
    I think I will bail out here as too many comments being made without people reading the whole thing from the start.
  3. #48
    Mar 2011
    1,555
    So what do you actually want, a recommendation on a 220-380 VFD or help resolving the issue with the motor not working?
  4. #49
    Mar 2014
    North Queensland
    38
    I thought I was done with this thread as it went on far too long but I realised to leave it hang without some sort of conclusion would not be helpful to others that might come across similar issues.
    In my view,conclusions to be drawn are that due to lack of input parameters regards current draw both the 1.5 and 2.2 KW budget VFD units were incapable of starting a 1.0 KW unloaded motor in Delta
    There is no indication the machine has mechanical problems , the motor itself is not faulty , connections are correct and burnt out old sparky hooking it up `seems` to know what he is doing .
    An explanation of the attached photos is as follows
    # 1 shows the motor started and running unloaded Star connected drawing 0.9 Amps ( the amps shown are indicative of the 3 phases ) shortly after the motor stalled when trying to mechanically engaging the load.
    # 2 shows the c/o switch selected from Star to Delta ( very smooth ) motor slightly louder, ammeter shows a current of 2.6 amps unloaded.
    # 3 shows a current draw of 4.2 amps fully loaded ( motor namplate FLC 5.00 Amps 220 volt Delta connected )
    # 4 shows a start attempt in Delta with an instantaneous Overcurrent message on screen. All this is not a one off but a consistant issue.
    The switchover from Star to Delta has no discernible effect on the VFD. As has been stated before more than once VFD`s don't like being switched when underway, time will tell
  5. #50
    Mar 2014
    North Queensland
    38
  6. #51
    7,189
    What accereratin time are you using?
  7. #52
    Nov 2007
    Near Rockhampton
    270
    Let it go Bob. OP's happier without questions.
  8. #53
    Mar 2014
    North Queensland
    38
    To Bob , Have tried it all, as GuzziJohn says time to put it to bed.
  9. #54
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by jcatcmc View Post
    Here you go monchochos, photos are the highest my skill set will go. If you find an input I hope its not too obvious.
    Attachment 388277Attachment 388276
    I understand that that is what you received with the VFD, but it appears to be lacking a hell of a lot of programming codes.....like 3 or 4 pages of them.
  1. Replies: 14
    Last Post: 4th May 2012, 08:48 AM
