Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: plug
  1. #16
    7,189
    FWIW I have been in contact with Steve and offered to run my meters over the motor but he has already moved on to using another motor.
  2. #17
    Jul 2010
    9,088
    I was trying to furnish a reference re legality of diy wiring wiring for steves home state. .Even though it has a mining reference it still reads pretty clearly.
    Then we'll have to agree to disagree.
  3. #18
    Jan 2004
    Mackay North Qld
    6,446
    This is what I should have posted.
    https://www.commerce.wa.gov.au/publi...ical-work-done
    Agree or disagree with it, it is the law.
  4. #19
    Jul 2006
    Athelstone, SA 5076
    4,258
    royce cross has all the info on their web site..look up air movement motors and follow through to 3 speed motors etc. wiring colour code will be same for all, except that capacitor rating change
  5. #20
    Jul 2010
    9,088
    Ok I guess we wont then.
    You're still wrong.
    Are we having fun yet?
  6. #21
    Jun 2010
    Canberra
    1,322
    My understanding is that non-fixed electrical work is allowed to be performed by an unlicensed person, provided they are "competent". Non-fixed meaning anything with a plug. I believe Qld is the only state that doesn't allow this. As for competent, I expect the only person you'd need to prove that to is a coroner.
  7. #22
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by RustyArc View Post
    Pretty sure you're wrong. Sadly.
  8. #23
    Apr 2018
    168
    Sadly he's right. Any "competant" person can perform electrical wiring on a appliance connected by a plug and cord.
    Hell in Victoria a caravan is deemed to be an appliance....
  9. #24
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Sparksy View Post
    OK, but what is the definition of competent for the purposes of the Act/Regs?
    I'll take your word for that. However, even if it's true, my understanding is you can't repair your own appliances in VIC. So you still can't do your own 240V caravan wiring.
  10. #25
    Nov 2007
    melbourne australia
    3,228
    After a little bit of Googling the only reference I can find to "competent person" with respect to electrical wiring relates to Test & Tag personnel.
    I say you can't legally repair electrical appliances unless you are licensed.
    I would LOVE to be wrong.
  11. #26
    Jun 2010
    Canberra
    1,322
    This is just for NSW, but it defines electrical work, then an electrical installation, and what that does not include.
    Under the not included is:
    any electrical article connected to, and extending or situated beyond, any electrical outlet socket
    https://www.fairtrading.nsw.gov.au/t...ons/electrical
    I believe most appliance repair people are not licensed (although even less sure what happens in Qld), which makes sense, as the skills required to repair a welder are completely different to installing a Tastic.
  12. #27
    Jul 2010
    9,088
    Sadly he's right.
    Sad or not sad, its the law.
    See what I did there?
  13. #28
    Nov 2007
    melbourne australia
    3,228
    Such repartee.
    I believe we still don't have a definitive answer on whether a non-licensed person can legally fit a plug to an appliance (in this case a motor). Clearly the requirements vary by State. Even if a particular state doesn't require a license (i.e. NSW), there seems to be a requirement for the person to be competent. And I can't find a definition of competent for the purposes of performing one's own appliance repair.
    Anyone found one?
  14. #29
    6,480
    My concern over this was simply from a safety point of view !
    You cannot fit five wires into a three pin plug safely. You have to have some method of connecting all five wires in such a way that it is safe to handle.
    The suggestion I made to use an insulating box where all five wires could be safely terminated and the desired three wires brought out to a plug was one way of doing it !
    A competent person is one that has an understanding of and about what they are doing ! This implies that they are knowledgeable. The OP obviously didn't understand, which is why he asked here and then subsequently decided not to continue with the idea.
    JMTPW.
  1. 15A Plug to 10A Socket (Again)
    By Chas in forum ELECTRICALS
    Last Post: 3rd Feb 2020, 11:38 PM
  2. 15 Amp Plug
    By bwal74 in forum ELECTRICALS
    Last Post: 13th Jan 2019, 12:22 PM
  3. Bottoming/Plug Taps
    By marty989 in forum METALWORK GENERAL
    Last Post: 30th Nov 2012, 12:33 PM
  4. 15amp plug on welder
    By garfield in forum WELDING
    Last Post: 17th Jul 2010, 09:34 PM
