Results 1 to 15 of 49
Thread: First star to delta conversion
17th Jun 2020, 02:53 PM #1Golden Member
- Aug 2015
- Melbourne, Australia
- 843
Hi all,
I'm prepping to do my first 3ph motor star to delta conversion. I saw it done last year when a kind forum member helped with an old Hercus hacksaw motor, and after some vids and research, I reckon I can give it a go myself. I am a sense-confessed, fully-paid, card-carrying electrical dunce. It's not my strong point. I still need to get some raw materials like the appropriate wire to extend stuff (with heat resistant shielding).
The candidate motor is some good Aussie kit. This guy - it is star only at the moment:
I have a question:
There is a 4th wire in there labelled as 'N' (Neutral I guess). I'm not sure how that fits into the Delta picture and what it should be connected to when all is done - if anything. Any hints?
Many thanks,
Greg.
17th Jun 2020, 03:38 PM #2Most Valued Member
- 2,672
That N wire is connected to the star point. Essentially it goes away when you do the delta conversion.
You find where that connects to the 3 windings, separate them, then you need to connect the "star end" of the L1 winding to L2, star end of L2 to L3, then the star end of L3 to L1.
17th Jun 2020, 03:49 PM #3Golden Member
- Aug 2015
- 843
Thanks Steve - appreciated. I had a suspicion that it became redundant in delta. So, just leave as unconnected to anything? (with sealed ends).
I am guessing if anybody wanted to reconfigure as star, then they'd need to take this into account.
17th Jun 2020, 04:13 PM #4Member: Blue and white apron brigade
You do realize that motor is already star connected? And why would you want to convert a 415V delta to star conversion? That would make it a 690V motor.
17th Jun 2020, 04:20 PM #5Most Valued Member
- Sep 2010
- Lebrina
- 1,915
I'm wondering the same thing BobL.
17th Jun 2020, 04:58 PM #6Pink 10EE owner
- 6,218
17th Jun 2020, 05:01 PM #7Golden Member
- Aug 2015
- 843
Thanks all,
Just showing how little I know here. My apologies.
My understanding was a 415v star motor converted to delta config enables it to run as 240v three phase using a 240v VFD. On other motors I have the connector box has the ability to reconfigure the 415 star to run as 240v delta. Not this one.
Do I have that wrong? .. or am I using the wrong terminology?
Apologies again - like I said - not my strong point ...
Greg.
EDIT: Bobl: when I said "I am guessing if anybody wanted to reconfigure as star, then they'd need to take this into account." .. I was meaning _after_ I had done this, if anybody wanted to undo the delta and make it star again.
17th Jun 2020, 05:01 PM #8Most Valued Member
- Healesville
- 2,129
Stray, you might want one of these https://www.aliexpress.com/item/4000...archweb201603_
17th Jun 2020, 05:07 PM #9Member: Blue and white apron brigade
OK I understand now.
17th Jun 2020, 05:13 PM #10Golden Member
- Aug 2015
- 843
Shed, I didn't even know such a thing existed to be honest. Is that real then? Does power drop to half or something?
But, I have a 240v VFD already that'll do the job if this thing was 240v 3 phase. And I'm not sure anybody want to wait for goods from China! Maybe that is better now.
BobL: thanks - it is a very dangerous thing me talking about electricity - especially to people who actually _know_ what they are talking about! - my brain gets most things, but there is something about electrics that just doesn't ever sink in .... like the million requests to not leave my socks on the floor ....
17th Jun 2020, 05:16 PM #11Most Valued Member
- 2,672
Pretty confident you've got it right. 415v star becomes 230v delta. Both have 230v across each winding.
Remove that wire - no point in having it in there. Extend the other ends of the windings out to the terminal block and you'll be able to set it up like a normal dual config motor so that it can just be jumpered at the terminal block.
17th Jun 2020, 06:12 PM #12Member: Blue and white apron brigade
I have a motor identical to that one that I converted. I wouldn't remove that grey wire - pull the grey insulation off and your should see 3 wires (start point) which are the other ends of the 3 coils. Separate these wires out and they should show continuity with the red(R), Yellow(Y) and brown(B) wires.
Then you may need to extend the separated wires and mark the one continuous with the red wire as R1, same for the other two, B1 and Y1.
Then connect Y1 to R on its terminal, R1 with B on its terminal, and R1 with Y. Then the 3 phases on top of each of those.
17th Jun 2020, 06:21 PM #13Golden Member
- Aug 2015
- 843
Ace. Thank you. That gives me a lot of confidence.
Thank you all. I'll post back my success story .. hopefully!
I really appreciated the advice and wisdom.
Thank you again all.
Greg.
17th Jun 2020, 06:38 PM #14Member: Blue and white apron brigade
I found a photo of my motor.
17th Jun 2020, 06:56 PM #15Golden Member
- Aug 2015
- 843
Nice! Is the red arrow significant?
Easy Star to Delta conversion
By lamestllama in forum ELECTRICALSReplies: 12Last Post: 4th Dec 2018, 10:33 PM -
Hercus Lathe motor Star to Delta conversion,
By LexD in forum THE HERCUS AREAReplies: 2Last Post: 14th May 2018, 10:59 PM -
Delta or Star
By Auskart in forum METALWORK GENERALReplies: 12Last Post: 21st Apr 2017, 05:26 PM -
3 Phase Star and Delta
By Auskart in forum METALWORK GENERALReplies: 14Last Post: 12th Jan 2016, 10:49 PM -
Star/Delta motor wiring
By .RC. in forum METALWORK GENERALReplies: 33Last Post: 3rd Mar 2012, 11:01 PM
