Results 1 to 6 of 6
Thread: Noisy lathe at startup.
15th Jun 2020, 08:04 PM #1Member
- Apr 2020
- Ettalong Beach NSW
- 62
- 72
Hi all, my recently acquired Sheraton Conquest 10 sounds like it isn't happy on startup. I've attached a brrief vid. sometimes it goesd on for longer, but of course, everytime I went to record, it only groaned briefly.
Any thoughts would be appreciated. (Starter condensor?)
Is it something I need to fix in a hurry?
15th Jun 2020, 08:55 PM #2
Hi Vic,
Have you checked the gearbox oil recently ? It sounds like dry gears until they get splashed with lube.Best Regards:
15th Jun 2020, 10:36 PM #3Member
- Apr 2020
- 62
- 72
Thanks. The headstock reservoir oil has been changed and is at the proper level.
As far as I know the quick change gearbox gears get lubricated but don't have a reservoir.
In person, the sound seems to come from the rear, around the motor area.
15th Jun 2020, 11:04 PM #4Member: Blue and white apron brigade
Single or three phase.
If its single it could be a loose centrifugal switch?
If its single I would be checking that out before running it again. If it comes off that can make a real mess,
16th Jun 2020, 06:07 AM #5Member
- Apr 2020
- 62
- 72
Single phase. Thanks, I'll have a look.
12th Jul 2020, 07:27 PM #6Member
- Apr 2020
- 62
- 72
Update
I had an electrical guy have a look and he cleaned it up and found part of the inside casing rubbing against the rotor. Sorted that and it runs smooth as silk now!
lathe how noisy
By texx in forum METALWORK GENERALReplies: 10Last Post: 7th Jun 2013, 08:09 PM -
Al-960b gears a bit noisy
By steran50 in forum METALWORK GENERALReplies: 19Last Post: 21st Mar 2013, 08:18 PM -
Noisy Spindle - Hercus Model O
By gdonald in forum THE HERCUS AREAReplies: 61Last Post: 31st Oct 2011, 06:24 PM -
9"c noisy back gears.
By azzrock in forum THE HERCUS AREAReplies: 7Last Post: 19th Apr 2011, 01:51 PM -
Noisy electric motor
By Bryan in forum METALWORK GENERALReplies: 14Last Post: 15th Jun 2010, 08:49 AM
