Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
  1. #31
    Jun 2010
    Canberra
    1,322
    So the first layer of windings was reasonably neat, the second layer a little more random, and after that I tried to avoid overlaps, but it became very difficult to control. Also, it was pretty much impossible to get the 1mm dia wire to sit flat down through the former. The end result was that I was left with about 500mm of wire I couldn't fit onto to the coil. This is how it looked:
    Joined into the other coils with heatshrink and everything smooshed into place:
    And evidence covered up:
    And then just reconstruct into a pump (Grundfos have excellent videos on how to reconstruct a multi-stage pump - sooo many bits to be put on the right way in the right order):
    It runs, and the app seems to think it's OK:
    So now need to hook it up to a tank and test it...
  2. #32
    Jun 2010
    Canberra
    1,322
    So this morning I had the chance to hook the pump up to a tank. The good news is that it appears to be working perfectly, the bad news is that I should have made more of an effort with varnishing the coil - the motor has a sort of grinding buzz as if something is rubbing, but I worked out it's the intermittent energising of the coil by the variable frequency drive. It's not the worst thing in the world, but it'd be nice if it wasn't so noisy.
    I did spray the coil liberally with circuit board lacquer from both sides, hoping the thin lacquer would wick into the coil. However being so thin, a fair bit dripped off, and I don't really know how far it penetrated.
    I think my three options are to ignore it, try spraying it with more lacquer, or try dipping it in varnish, the latter which I'd have to hunt down if it's a special kind.
    In the mean time I think I'll commission it in a nursery where they water from a tank and the current pump is a bit too small, and see how it behaves.
  3. #33
    6,481
    Thumbs up
    Hi Rusty,
    You might find that some of the spray varnish has got onto the inside wall of the stator surface and is rubbing slightly at some point. If this is the case the noise will reduce with use as the rotor warms up and wears it away.
    whilst the rotor will be accurately centred, the stator can be a few thou away from true, particularly if there is a bit of debris that is trapped under one edge when you put it back into the case.
    Anyway you have successfully repaired the machine, saved some money and got it back in service.
    Good one.
  4. #34
    Jun 2010
    Canberra
    1,322
    Hi Rusty,
    Good one.
    I'm pretty confident there's not interference between the rotor and stator - I ran some 400 grit wet and dry over the inside of the stator before assembly to remove minor residual surface rust from its time being half immersed, and spent a while remounting the rotor and front plate to make sure everything was spinning freely. The rotor is a fancy permanent magnet type, so I was a bit concerned about bits of random metallic crud sticking to it, but I think I'm OK.
    I'm hoping it's all good. If you want to know what it's worth, google Grundfos CMBE 3-62 . If I get motivated, I might have a go at talking to it over its RS485 "Genibus" interface, which looks to be Grundfos's in-house modbus-like protocol.
  1. Cleaning stator windings on a grinder
    Last Post: 24th May 2012, 03:52 PM
  2. Dead Bench grinder?
    By jimmyratsbreath in forum METALWORK GENERAL
    Last Post: 29th Oct 2011, 12:59 AM
  3. 1/2 notch dead centre
    By tanii51 in forum METALWORK GENERAL
    Last Post: 15th Feb 2010, 08:46 PM
  4. CIG Eaywelder EC - dead
    By nexusone in forum WELDING
    Last Post: 24th Nov 2008, 10:26 PM
  5. #2mt Dead Centre
    By DJ’s Timber in forum METALWORK GENERAL
    Last Post: 24th May 2007, 08:50 PM
