Results 1 to 5 of 5
    Feb 2012
    Tamworth, NSW
    205
    Default 2 speed switch wiring - 3 phase motor
    Hi there
    I am hoping someone may be able to chime in with some advice on wiring up a switch that is on an old BCA Jig borer. The machine has a 3 phase 2 speed motor. The three phase power comes into the machine stand isolation switch and then from there to the two speed switch. On the power input side to the switch there are 4 wires - the three phases and an earth. On the motor side there are 6 wires and happily they are tagged with wire identifier and these match up with the switch terminals so this all seems very straight forward and matches the wiring diagram I have which I have attached a pic of.
    Here is the switch
    My confusion is that there is no obvious terminal to run an earth wire (the 4th wire come in on the power side of the switch). I am not sure where this should go?
    Interestingly there is one terminal that has been left wired as shown below - this is the only wire that was left on the switch and all other wires were tagged and it is obvious where they go. B1 green wire connect and then there is the black wire to the only terminal on the switch that doesn’t have a label on it which has made me suspicious of it and if.
    So can anyone shed any light on where I should be looking to send the earth to?
    6,480
    Hi Danger Mouse,
    The earth wire goes to the frame or body of the machine ! In the case of the switch it would probably be under one of the screws that fasten the switch to the machine.
    Feb 2012
    Tamworth, NSW
    205
    Hi Danger Mouse,
    Thank you Baron, that had been my first thought and then I started to second guess myself.
    Jul 2010
    9,088
    Hi,
    Is there any single phase required on the machine?
    One thing to watch for on old machines is earth used as neutral.
    I don't think its the case here but I wonder where the other end of that green wire is.
    Feb 2012
    Tamworth, NSW
    205
    Hi,
    From the switch there isn’t any single phase and I have it running successfully now. Interestingly on the machine from the initial isolation switch a single phase line does go to another box that seems to have a transformer and outputs a DC current that connects to a lamp. The reason I say it appears to do this is that the end of the light has a 2 pin polarised plug like you see in caravans and other 12v outlets. The wiring here is all connected and no need for me to touch it.
  1. Replies: 2
    Last Post: 29th Sep 2018, 06:19 PM
  2. Replies: 0
    Last Post: 25th Mar 2018, 06:58 PM
  3. Single Phase Motor Wiring
    By grunto in forum METALWORK GENERAL
    Last Post: 18th Sep 2015, 12:26 PM
  4. Single phase induction motor wiring help needed
    By simonl in forum METALWORK GENERAL
    Last Post: 21st Apr 2012, 05:23 PM
  5. Wiring of a single phase motor.
    By krisfarm in forum METALWORK GENERAL
    Last Post: 28th Oct 2010, 08:10 PM
