Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Jul 2010
    9,088
    Default Reversing a used brush motor
    This maybe a question no one can answer but you never know your luck.
    I have a 3 chamber diaphragm pump 12VDC pump that I have always suspected was wired backwards, if this sort of motor would even have offset brush timing(if that is what is is called). You cant see in the picture but the exposed pin on the lead from the battery is +, which you would have to think was wrong along with the colors changing at the plug.
    I've pumped over 2000 litres without issue but now have other pumps that have the wiring done correctly. I could do without having to have different leads for each pups.
    Anyone think revering revering the pump would be a really bad idea?
    Might just have to cross my fingers.
    Sep 2005
    Bendigo
    60
    419
    So if I am understanding you correctly the positive goes to black on the motor ?
    In some American wiring black is active, in which case it maybe correct.
    6,477
    Hi Stuart,
    Its difficult to see in the picture but that looks like a flat vane type pump, not a diaphragm one, and the inlet/outlet appears to be at 90 degrees to the shaft axis. In which case it couldn't care less about which direction it runs in. The only point I would worry about is if the impeller was screwed onto the shaft, in which case running it in the wrong direction it could unscrew.
    Now if it really is a diaphragm pump, motor rotation direction might not matter !
    I use a diaphragm pump for the water delivery in my camper, it runs equally well in either direction.
    Oct 2007
    Alexandra Vic
    69
    654
    If the unit utilises a field wound brushed motor, reversing the voltage polarity will not reverse the direction of rotation. To do that you need to reverse the magnetic polarity of the armature relative to that of the field windings, by swapping the cables between the field winding and brush holders. Simply reversing applied voltage polarity will reverse the magnetic polarity of both sets of windings and result in the same direction of rotation.
    On the other hand if the motor utilises a permanent magnet field rather than a wound one, reversing the applied voltage polarity will reverse the direction of rotation, as you are reversing the armature magnetic polarity and leaving the field polarity unchanged, so you are reversing the polarity of one relative to the other.
    For a diaphragm pump, direction of rotation should not affect the pump efficiency, the diaphragm simply moves in a chamber to create a vacuum and draws fluid in through a check valve, then moves in the opposite direction, which closes the first check valve and traps the fluid in the chamber and ultimately creates enough pressure in the chamber to force the fluid through a second check valve to the outlet once the chamber pressure exceeds the static pressure present at the outlet. As the pressure in the chamber reduces with fluid flowing into the outlet, the second check valve will close. Once the diaphragm reaches the end of its travel, it reverses direction again and starts to create a vacuum that will open the inlet check valve and draw more fluid in for the next pump cycle.
    Jul 2010
    9,088
    Hi Guys
    Thanks. Looks like reversing shouldn't be an issue. I have some spraying to do tomorrow so I will get it done an let you share the blame if the pump dies. lol
    Quote Originally Posted by droog View Post
    Yes, But what I failed to mention is the pumps are from China and that one of the "other pumps" I mentioned is the same sprayer just wired differently(correctly?).....one of them has to be wrong
    Hi Stuart,
    Pretty sure its a diaphragm, but pumps are not my strong point. Here is a better look.
    I added a 750ml pressure tank as I didn't like the pump cycling every time I gave something a squirt.
    Quote Originally Posted by malb View Post
    I haven't been inside it so cant say if its permanent magnet or not.
    Now off to change the wiring.
    6,477
    Hi Stuart, Guys,
    Very difficult to tell. Really the only way would be to have a look inside.
    Jul 2006
    Athelstone, SA 5076
    4,258
    my persoanl experience having worked for for a us international co....they use black for everything...but they generally make it very easy by numbering the wires...
    Nov 2008
    Sydney
    112
    In the US the older standard colours for AC line cords was black active, white neutral, and green earth. As far as I recall, DC has always been red+ and black-.
    Chas.
    Jul 2010
    9,088
    Well it run 120 litres of spray today, so I'm calling it good.
    Now I only need one wiring setup for all three sprayers, one less thing to keep track of.
    Lets hope it doesn't come to that for awhile yet
    Thanks to all.
    Aug 2011
    4,779
    A little late in on the conversation but it does seem to be a diaphram pump eventhough the shape is somewhat deciptive. The giveaway I suspect is the pressure switch. Correct me if I'm wrong but the operation of the pump cycles on and off depending on whether you have your hand on the spray trigger. Pull the spray trigger, pressure drops and the pump kicks in. It would be very unsusual to use a centrifugal pump for such a setup.
    Also in operation, diaphram pumps tend to have a slightly pulsed output whereas centrifugal pumps produce a more even flow output.
    Diaphram pumps work by being pushed open and closed by a rotating cam arrangement. The geometry for the cam (leading and trailing edge) may be optimised to run in a specific direction but it will still work in any direction and in any case I don't think diaphram pumps used for weed sprayers and caravans etc. are very hi tec or fussy.
    Of course if it blows up then I guess it's another thing that I didn't know that I didn't know about!
    Sep 2005
    Bendigo
    60
    419
    Quote Originally Posted by Chas View Post
    Chas.
    Yes standard was for AC but did not stop them from putting out DC equipment with black +ve and white -ve.
    6,477
    Hi Simon,
    A little late in on the conversation but it does seem to be a diaphragm pump even though the shape is somewhat deceptive. The give away I suspect is the pressure switch. Correct me if I'm wrong but the operation of the pump cycles on and off depending on whether you have your hand on the spray trigger. Pull the spray trigger, pressure drops and the pump kicks in. It would be very unusual to use a centrifugal pump for such a setup.
    Also in operation, diaphragm pumps tend to have a slightly pulsed output whereas centrifugal pumps produce a more even flow output.
    Diaphragm pumps work by being pushed open and closed by a rotating cam arrangement. The geometry for the cam (leading and trailing edge) may be optimised to run in a specific direction but it will still work in any direction and in any case I don't think diaphragm pumps used for weed sprayers and caravans etc. are very hi tec or fussy.
    I was thinking a vane pump, more along the lines of several rigid blades running along the chamber walls. A centrifugal pump doesn't provide much pressure, where as a vane pump could, as could a diaphragm pump.
    But you are right, a diaphragm pump does provide a pulsating output, hence the accumulator. I used a plastic coke bottle as one on the camper. Interesting to watch it start to fill with water and then stabilise about half full.
    Jul 2010
    9,088
    Morning
    Yes, as supplied.
    Not to any noticeable extent on this pump. But the triangular shape of the end of the pump makes me think its a 3 chamber pump. So I guess its much like the 3 phase v single phase motors the output is more stable? Though the geometry/timing of the cams would effect this.
    I added the accumulator as I didn't think it was the greatest idea to be cycling the pump as often as I was(although in fairness it did put up with it for about 700 litres of spray, how every many starts that was). The only down side is if spraying a long time with a fine spray the pump cycles now and again, but its not nearly as often so I think I am much better off.
    The coke bottle is a great idea. Cheaper than my $35 accumulator and no need to worry about the bladder being effected by the chemicals(which it would seem it is not, but that was a lucky guess lol)
    6,477
    Hi Stuart, Guys,
    I notice that in the camper when you have the tap open and the pump stops, water carries on running for a short time while as the accumulator empties, the reverse happens as well. The pump runs for several seconds before the water starts to run. But it does very effectively smooth the flow. Most noticeable in the shower before fitting the coke bottle.
  15. #15
    Oct 2010
    melbourne, laverton
    1,910
    haha your funny
    I usely dont start suspecting my pumps untill. the toilet level goes up instead of down.
    equipment starts running hotter.
    theres liqiud coming out of it or there is a funny noise.
    .I think id just run the pump off a hand drill in fwd then rev for a bit and see if there was much difference.
    but the hole time i was stuffing around with the pump. Id be wondering" does direction of rotation .make any differance""
    aaron
  1. Damaged motor reversing drum switch
    By Flo in forum ELECTRICALS
    Last Post: 14th Jun 2019, 09:58 PM
  2. Help needed in reversing direction of a DC motor
    By simonl in forum METALWORK GENERAL
    Last Post: 12th May 2018, 02:31 PM
  3. Reversing Switch
    By wheelinround in forum METALWORK GENERAL
    Last Post: 22nd Feb 2015, 03:34 PM
  4. Reversing lights on trailers?
    By Bazzmate in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 11th Jun 2009, 11:39 PM
  5. Reversing a 440 to 220 volt transformer is it possible ?
    By Plushy in forum METALWORK GENERAL
    Last Post: 13th Nov 2008, 08:53 AM
