Results 16 to 16 of 16
Thread: Reversing a used brush motor
24th Feb 2020, 09:08 PM #16
Hi Aaron,
The camper has a cassette toilet and its own built in water supply that is manually filled, so its not filled by the camper water pump.
The pump itself has a pressure switch that turns it on and off, so when you turn a tap on, the water pressure drops and the pump starts a few seconds later. Turning off the tap causes the water pressure to rise, stopping the pump. The stop/start delay is caused purely by the action of the accumulator, which behaves like a spring, only its the compression of the air contained inside it.Best Regards:
Damaged motor reversing drum switch
By Flo in forum ELECTRICALSReplies: 7Last Post: 14th Jun 2019, 09:58 PM -
Help needed in reversing direction of a DC motor
By simonl in forum METALWORK GENERALReplies: 26Last Post: 12th May 2018, 02:31 PM -
Reversing Switch
By wheelinround in forum METALWORK GENERALReplies: 0Last Post: 22nd Feb 2015, 03:34 PM -
Reversing lights on trailers?
By Bazzmate in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 11th Jun 2009, 11:39 PM -
Reversing a 440 to 220 volt transformer is it possible ?
By Plushy in forum METALWORK GENERALReplies: 6Last Post: 13th Nov 2008, 08:53 AM
