Results 1 to 15 of 21
Thread: Powering a 3 phase VMC at home?
4th Feb 2020, 06:01 PM #1Senior Member
- Mar 2017
- Brisbane
- 245
I'm trying to power a https://www.machineryhouse.com.au/m905 at home. It has a 2.2kw spindle, 650w coolant pump, three 1.5kw servos (from my research). I have 30 amps of regular 240v single phase power from two 15amp outlets run in parallel. I cannot find info on the total peak power draw of the machine, but my friend who speaks German is going to find out later....
1st option/question:
If I could get my hand on a large enough powerwall, how much would I need to spend to get a 415V inverter and other equipment to power the cnc mill? I would charge it with 240v (somehow)
2nd option:
I can get a rotary phase converter, but would I need an 8kw phase changer one? They are like $6500. Phase changer are an awesome company im sure but i just need to get this thing going....
3rd option:
Generator - just for home hobby use - what sort would I need? I did some googling and Im confused what is and whether I need AVR, pure sine wave, $2000 generator, or $8000 generator. Not knowing power requirements of mill makes it harder.
Thanks for any help *projects a large batman like symbol into the sky in the image of BaronJ asking for help*
4th Feb 2020, 06:38 PM #2
Hi J3dprints,
I saw the mental image of the penguin projected on the clouds
Just add together all the watt ratings and do the P/V=I to get the current draw.
It looks like you have 7.35 Kw there, so 7500/230=32.5 amps. Your two outlets are going to be right up to the max.
HTH.Best Regards:
4th Feb 2020, 06:43 PM #3Member: Blue and white apron brigade
- 7,183
The biggest 240v single-three phase VFDs are about 4kW. But for not much about $500 you could by 3 vfds and power all motors independently AND have a MUCH better device. Eg have better motor protection, be able use speed control, jog, fast/slow start, braking separately. But it would require the motors to be compatible with 240v vfds and am almost a complete rewire of the mill. I did this for just 2 motors on my little mill and it was a fairly big job but we’ll with it on the end but I would not like to be doing that on that mill. Too much automation, interlocks etc.
4th Feb 2020, 06:49 PM #4Senior Member
- Mar 2017
- Brisbane
- 245
Thanks Baron, but the 1.5kw servos are highly unlikely or not able to operate at peak power together, you would need to be doing a heavy cut diagonally UP as all axis would be turning. The spindle of course would need to be drawing 2.2kw too.
4th Feb 2020, 06:55 PM #5Member: Blue and white apron brigade
- 7,183
Thought it was 3 motors but now see it’s 5 so <$1000.
4th Feb 2020, 06:57 PM #6
Just to add, my estimate based on peak power requirements. All these motors have surge current requirements !
3rd option:
Generator - just for home hobby use - what sort would I need? I did some googling and I'm confused what is and whether I need pure sine waveLast edited by BaronJ; 4th Feb 2020 at 07:01 PM. Reason: Added info
4th Feb 2020, 07:12 PM #7Senior Member
- Mar 2017
- Brisbane
- 245
Thanks Baron, any rough idea on price for a generator that could be relied upon to not fry my electricals?
4th Feb 2020, 08:07 PM #8Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
why not just get 3phase connected to your house? Be very careful running cnc machines off phase converters and generators, some controllers don't play nicely with dirty power. Running off a phase converter may also affect your warranty, assuming it is new.
4th Feb 2020, 08:19 PM #9Senior Member
- Mar 2017
- Brisbane
- 245
I got this data from the manual they sent me:
Total Connection:
3 x 400V ~ 50Hz 12 KVA
( 3 x 400V ~ 50Hz 14 KVA )
Power of spindle drive S1 operation 2.2 kW( 3.7 kW )
Power of spindle drive S6-30 % operation 3.2 kW( 5.5 kW )
Not sure why the second is in brackets.
Does that mean I need a 12kw supply? Or 14kw supply?
4th Feb 2020, 08:20 PM #10Senior Member
- Mar 2017
- Brisbane
- 245
4th Feb 2020, 08:37 PM #11Most Valued Member
- 2,651
I did a bit of price research last year around generators for backup purposes at work. Worked out around $1000 per KVA for quality generators in the 1-10kva range. That was single phase but a quick look online just now looks like its about right for 3 phase too.
In your situation I'd definitely be hiring one first for proof of concept.
Thinking outside the square and along your lines of a powerwall, you might be able to pick up a cheap used 3 phase UPS (backup power supply). My understanding is that they are essentially a 3 phase inverter, supplied by the internal bank of batteries when input power is out of limits.
Sort out a way to charge the batteries either externally or possibly they will charge from one phase anyway.
Even if the batteries are a bit suss, it would make a great power conditioner for a less than perfect 3ph generator.
Just a thought.
4th Feb 2020, 10:05 PM #12Senior Member
- Oct 2015
- melbourne
- 473
A 5kva inverter charger is about $3k, plus wiring etc say 10k.
Then batteries, assuming an average load of say 5kw, you'd need say 15kwh of batteries to give 2 hours running. Maybe another $2500
With single phase charging, at 5kw, you'd need 2 hours charging for 1 hour running.
So all up under $15k?
4th Feb 2020, 11:59 PM #13China
- Dec 2005
- South Australia
- 1,656
You must have very compliant neighbours
5th Feb 2020, 04:14 AM #14
5th Feb 2020, 04:24 AM #15
Hi J3dprints, Steve, Guys,
That is probably a good idea ! See my note below.
Just a thought.
I would be very wary of UPS supplies. I am not aware of any that produce clean sine wave output. Not that they couldn't. They output what is known as a "modified sine wave" which is actually a series of square wave steps. Computers and a lot of equipment have their own, usually switch mode power supplies built in. These tend not to care about the quality of the feed power, simply because of the way they work.Best Regards:
415v three phase from 240v single phase a home made digital phase converter?
By lamestllama in forum ELECTRICALSReplies: 26Last Post: 20th Sep 2018, 07:35 PM -
Homemade rotary converter 230v single phase to 415v three phase (Video)
By Tilly819 in forum ELECTRICALSReplies: 0Last Post: 27th Jul 2018, 09:12 PM -
Powering a 3phase pump with single phase
By MOA in forum METALWORK GENERALReplies: 13Last Post: 15th Jul 2015, 06:59 AM -
Steam engines powering rice mills
By .RC. in forum METALWORK GENERALReplies: 0Last Post: 26th Apr 2015, 08:07 PM -
Huanyang VFD - How to get single phase outputs from VFD 3 Phase output points (U,V,W)
By AP-R*D in forum METALWORK GENERALReplies: 14Last Post: 4th May 2012, 08:48 AM
