Results 1 to 8 of 8
Thread: Machine Switches ?
21st Sep 2019, 11:44 AM #1
Machine Switches ?
I have a woodworking Machine (Chisel Mortiser) that fell over and took the full impact to the switch .
Complete Obliteration !
Where can I buy one ? I'm not capable of fitting such a thing without instruction so was thinking of having the switch here and ready for the next time an Electrician is here for work .
Its not a standard switch . Its single phase 240V magnetic switch like the three phase switches are I think . The Mortiser also has a capacitor between the switch and motor so this switch must have a lead from switch to capacitor to power that first ( I Think ?)
Whats it called and where do I buy if possible ?
Rob
21st Sep 2019, 12:42 PM #2Most Valued Member
Pity we couldn't get to see the front of whats left, as it's a bit hard to see if it's a rotary or 2 button on/off switch?
21st Sep 2019, 12:51 PM #3
21st Sep 2019, 04:42 PM #4
More details
Rob
21st Sep 2019, 05:05 PM #5
Hi Rob, Guys,
That looks like a three phase no volt switch wired to work on single phase. I'm not sure what that capacitor is supposed to be doing. 200 uf @ 125 volts I think from the picture. That diagram certainly shows a three phase circuit.Best Regards:
23rd Sep 2019, 05:54 PM #6Member
- Nov 2016
- Gulfview Heights, Adelaide
- 83
The "magnetic switch" is known by the name: "contactor"
The wiring diagram (3 phase) does not match the wiring, I am not sure why.
If you are looking at purchasing a contactor you will need to ensure you have the correct
coil voltage and current rating for this machine.
regards,
Paul
23rd Sep 2019, 08:27 PM #7Senior Member
- Jan 2012
- 149
I've used one of these, seem to be OK:
https://www.ebay.com.au/itm/230V-19A-NVR-Motor-Stop-Start-And-Emergency-Stop-Switch-5-Pins-For-Lathe-Mill-Dr/401727643410?epid=15018407899&hash=item5d88d55f12:g:JkcAAOSw619ch1hQ
24th Sep 2019, 03:07 AM #8
Vfd remote switches.
By eskimo in forum ELECTRICALSReplies: 9Last Post: 8th Jun 2019, 11:22 AM -
Auxilary changeover switches and so forth.
By .RC. in forum ELECTRICALSReplies: 6Last Post: 25th Apr 2019, 10:41 PM -
Fitting remote stop switches to PowTran PI-160
By peterbilt in forum ELECTRICALSReplies: 11Last Post: 19th Aug 2018, 09:19 PM -
Hall Effect Limit Switches
By Sterob in forum CNC ForumReplies: 19Last Post: 2nd Oct 2016, 10:41 PM -
CNC Mill Limit Switches
By electrosteam in forum METALWORK GENERALReplies: 8Last Post: 10th Sep 2010, 07:31 PM
