Results 76 to 76 of 76
Thread: Power feed buy new or repair?
23rd Nov 2019, 12:18 PM #76Golden Member
- Dec 2007
- 574
I've been away for 2 weeks and not sure where you are with this motor or even if you intend to try a rewind but you may find it easier to salvage the wire from the microwave oven fan motor if the wire size matches, I've found that the fan motor windings are usually not dipped in varnish which make it easy to get to the wire. The transformer is usually welded together which means taking a side grinder to it to get to the windings which are often - but not always - dipped in varnish.
Not sure what you have in your junk box but another good source of wire is old 3 phase contactor sets, the 24v coil ones will usually have wire that will be too thick but the 240v coils usually have wire around .12mm in diam.
Power Feed
By Auskart in forum METALWORK GENERALReplies: 22Last Post: 30th Dec 2016, 08:23 PM -
No.O Table Power Feed
By Anorak Bob in forum THE HERCUS AREAReplies: 5Last Post: 8th Jan 2013, 01:08 PM -
DM 45 power feed
By morrisman in forum METALWORK GENERALReplies: 32Last Post: 2nd Feb 2012, 10:34 PM -
Power feed for my mill...
By John Hill in forum METALWORK GENERALReplies: 3Last Post: 11th Jan 2012, 08:11 PM -
power feed for a HM-45
By Sterob in forum METALWORK GENERALReplies: 2Last Post: 2nd Oct 2006, 08:34 PM
