Results 16 to 20 of 20
20th Sep 2019, 07:56 PM #16Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
I have quite a few option to consider now:
1. Run the machine directly from my Phase Changer phase converter, obviously without variable speed.
2. Run the machine from the Phase Changer through a 415V in - 415V out VFD, which I have available.
3. Have the motor rewound to allow a 240v input VFD to be used.
4. Cut the flange off the existing motor and adapt it to suit a modern, standard, dual voltage flange mount motor.
5. I will try running the machine with the motor "as is" from one of my 240v VFD's, at reduced power and see how it goes.
6. The expensive VFD from the UK is not on my options list at the moment.
21st Sep 2019, 12:25 AM #17Most Valued Member
- Healesville
- 2,129
I have never used one of these but am am eager for someone else to try one
They are called a Delta VFD, so 220 single phase input and 380 3 phase output, a sample here https://www.aliexpress.com/item/3278...482f53ddVNTjxe
or pick another from here https://www.aliexpress.com/wholesale...itch_new_app=y
19th Jan 2021, 09:49 PM #18Golden Member
- Sep 2008
- 831
A quick update to this thread: the machine is now running perfectly on a 220 volt (1ph) input, 380 volt (3ph) output VFD by Ecogoo. When operating on 240 volt input the phase to phase output seems to be around 390 volts which is very close to the motors specified operating voltage. For around $120.00 from Aliexpress I think that this was the best option.
20th Jan 2021, 03:26 PM #19Golden Member
- Jul 2011
- 837
20th Jan 2021, 09:26 PM #20Golden Member
- Sep 2008
- 831
Link to the drive: https://metalworkforums.com/redirect...976184024.html
Autotransformer 240 volt to 415/480 volts
By paul33 in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 21st Nov 2018, 11:31 PM -
2.2kw - 3hp 240 volt motor 2800rpm
By dodge at4 in forum WANTED TO BUYReplies: 0Last Post: 28th Sep 2018, 08:37 PM -
VFD for 480 Volt single phase
By Kentower in forum METALWORK GENERALReplies: 13Last Post: 27th Mar 2014, 11:53 PM -
Hercus 260 - To convert to 240 Volt, or not
By dle147 in forum THE HERCUS AREAReplies: 30Last Post: 26th Sep 2011, 03:23 PM -
Reversing a 440 to 220 volt transformer is it possible ?
By Plushy in forum METALWORK GENERALReplies: 6Last Post: 13th Nov 2008, 08:53 AM
