Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Aug 2019
    Nambour Queensland
    63
    86
    Is it gear or belt drive.
    It's belt drive with a 4 section pulley and it really has no adjustment unless you unbolt the motor mount to change pulley ratio so a vfd would be a lot easier.
  2. #17
    7,188
    Quote Originally Posted by Hards2u View Post
    If you canslightly loosen the belts so they can slip if things go pear shaped then you could put up to a 1.5HP motor on it. To facilitate that you would need to use a 2HP VFD (they usually come in 0.5, 1 and 2HP and upwards varieties)
    When you program the VFD make sure you limit the power output (current) of the VFD so that it doesn't go above that needed for 1.5HP operation and you should be OK. That's how I would do it anyway.
  3. #18
    Apr 2012
    Healesville
    2,129
    Have you thought about making a hinged motor mount with an over centre tighten/release linkage and handle ?
    That cutter you have in the arbour will need a low ratio if you plan on using a 1/2 hp motor, clunk clunk clunk, I dont think the VFD will help with that.
    cheers, shed
  4. #19
    6,473
    That is a pretty little mill, would fit nice in my workshop as well.
  5. #20
    7,188
    I like sheds idea. If you can't or don't want to do that then I would not go bigger than 1HP.
  6. #21
    Aug 2019
    Nambour Queensland
    63
    86
    I would just like to know what it is. One day.
  7. #22
    Aug 2019
    Nambour Queensland
    63
    86
    I think I'll get a single phase 1 hp and do the adjuster which is something I thought it was always lacking in its design anyway. I would like to try a vfd as well because I have had nothing to do with them as yet. I'll get back when I succeed.
  1. Log Splitter Repair
    By jack620 in forum METALWORK GENERAL
    Last Post: 1st Jul 2018, 06:51 PM
  2. Casting Repair Help
    By wheelinround in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 19th Feb 2017, 03:13 PM
  3. Douglas repair
    By Steamwhisperer in forum METALWORK GENERAL
    Last Post: 8th Apr 2013, 10:11 AM
  4. BSA Motor repair.
    By Metalman in forum METALWORK GENERAL
    Last Post: 15th Apr 2011, 09:58 PM
  5. Guitar Repair
    By SurfinNev in forum METALWORK GENERAL
    Last Post: 31st Mar 2009, 01:52 PM
