Results 1 to 5 of 5
    Jul 2007
    sandstone point queensland
    69
    182
    Default replacing control switch for AL330 lathe
    want to replace my switch on my AL330 HAFCO lathe with the newer HZ5B-10 D008/2 SWITCH, ,and I wonder if anyone can help me? the wires on the existing switch are
    1 white
    2 red
    3 red
    4 blue
    5 black..........................
    6 brown 2,3 and 6 are linked with each other.
    attached is a photo of new switch, and old switch (still attached to lathe)have done the changes to the new switch so it fits ,just stumped on the wiring ,
    .......thanks in advance
    there was a post on this but a couple of the wires on mine are a different colour
    6,439
    Hi Robyn2839,
    replacing control switch for AL330 lathe-img_2951-jpg
    From the picture of the new switch it looks like when the switch is turned to the right, connections 2 & 4, are made and so are 6 & 8 and when turned to the left, 1 & 3 are made and so are 5 & 7. There won't be any connections made between the front and rear switch banks unless you deliberately link them.
    Jul 2007
    69
    182
    still not sure what wires from the old switch to connect to the new one ,but someone will haave done it as the old switches are no longer as far as I know, thanks for your help
    6,439
    Hi Robyn2839,
    From memory the contact layout is the same but the switch is rotated by 90 degrees.
    But I have no way of checking that.
    You really need a multimeter to check that this is correct. Both the front and rear sections are the same.
    Jul 2007
    69
    182
    pulled the switch out today to get a better look at it ,may help with id............bob
    PHOTO 3 reads LA32 XK06
    -101
    3091
    PHOTO 2 reads Ui660v Ith10A
  1. Replies: 5
    Last Post: 28th Aug 2019, 05:47 PM
  2. Hafco al330 metal lathe
    By robyn2839 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 9th Jun 2019, 10:07 PM
  3. Replacing a Switch.
    Last Post: 30th Apr 2017, 10:49 PM
  4. N.S.W. Hafco AL330 Metal Lathe LOC: Coffs Harbour NSW
    By BenM78 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 8th Jan 2013, 05:42 PM
  5. Trouble replacing lathe belt
    By dannyvee in forum METALWORK GENERAL
    Last Post: 13th May 2011, 01:11 AM
