Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Jul 2010
    9,088
    Default Intermittent pump fault
    I have a house pump that occasionally either starts slow(the water doesn't start to flow for a few seconds after the tap is turned on) or doesn't start at all(the controller then trips and needs resetting). Of course trouble shooting it is pretty much impossible as it always starts when I am standing next to it. My first guess is the cap is on the way out. Sound reasonable, and better ideas?
    Secondly the cap is 12uf +/-5%, the only (almost) direct replacement I can find is +/- 10%. Would I be correct in assuming that will make stuff all difference?
    Thank you
    7,182
    Thank you
    Yes.
    Even more so if it's a start cap.
    6,436
    Hi Stustoys,
    If it has a centrifugal switch, check that the contacts are clean and in good order. If it just has a capacitor and no centrifugal switch then yes the cap would be suspect. The tolerance of +- 10% is immaterial for a motor.
    I would check the switch first, in fact any switch that was in circuit, since the inductive arc will cause switch damage over a long period of time.
    Jul 2010
    9,088
    Thanks for that.
    I should have included more details.
    It is a run cap.
    link to said replacement. https://www.ebay.com.au/itm/271463063489
    Its the same manufacture(not a huge issue but at least the package is the same size)
    It has leads, mine has terminals.(not an issue)
    There are similar ones available with 5% but their V rating is lower, I assume they are meant for starter caps.
    https://www.ebay.com.au/itm/281317085292
    Oct 2007
    Alexandra Vic
    69
    654
    Your problem could be caused by issues other than the cap in the motor, and there isn't a lot of detail about the application given.
    Older style pressure pumps with the bulbous cylinder use a bladder in the cylinder and rely on air pressure in the bladder to regulate water pressure while the pump is not running, to reduce the number of stop start cycles the motor experiences. If the bladder becomes waterlogged or looses pressure for some reason it can affect starting at times and cause intermittent problems.
    If the pump housing is having solids enter it with the water, residues may be building up in the housing and jambing the impeller or adding enough extra friction to cause a slow start. It's also possible that small solids are occasionally blocking the entry port to the pressure switch so that the unit does not clearly sense a drop in pressure when a tap is opened. If the pump is an automatic type pump, it might pay to check the entire system rather than just blame the run capacitor and replace it. As suggested at the top, there isn't a lot of info about pump and it's water source, just an initial surmise that the cap is bad.
    Jun 2004
    Kyabram. Vic
    632
    Simon,
    Sounds like the pressure switch. They have a small port leading to a rubber diaphram where pressure activates the cut in/cut out springs. The port can block with debris and the spring mechanism can collect crud, and with age wear and jam. Replacement available from farm irrigation outlets. Last one I replaced cost somewhere around $125.
    Ken
    Jul 2010
    9,088
    More missing details
    No pressure tank.
    Anything going into the tank goes through 1mm screen.
    Pump inlet has a 250 micron screen.
    The two times that the pump hasn't started, the controller has known the pump hasn't started and signaled a fault. So I assume that side of things is working(short of the motor control relay not working correctly). I have a another controller though of course it is a 90 degree one and the current one is straight through, I could make it work though custom plugs make life harder.
    If I had a web cam with descent audio I'd try setting that up.
    If it would stop working life would be so much easier
    Thank you
    6,436
    Hi Stuart,
    Yes its very hard to diagnose an intermittent fault when it won't occur to order.
    Your controller probably looks for a loss of pressure before it times out and shows a fault.
    FWIW. Pressure switches can be obtained from automatic washing machines. They are used to set water levels and prevent the heater coming on without water. In a washing machine they use air pressure to measure the water level.
    Jun 2004
    Kyabram. Vic
    632
    Stuart,
    Sounds like you have an 'even flow' switch. My house pump has one and it goes on the fritz in hot weather (usually well over 40C). I bought a replacement but found that the original would still work if I turned the power off for a while then activated the switch reset button after powering on.
    Ken
    Jul 2010
    9,088
    As I understand it these controllers use a water wheel to measure flow. They trip when they sense no flow, to save the pump from running dry(granted not the issue in this case but it doesn't know that lol).
    Quote Originally Posted by Toggy View Post
    No, my pump is either on for off.
    Had another fail to start, but this time the pump didn't start with the first push of the reset, just hummed. Second press it started. I'm going with the cap. Yes it could be a few other things but having spare wont hurt and it is by far the easiest/cheapest thing to try. Not my favorite way to fix things but it will have to do.
    6,436
    Hi Stuart,
    What you are describing is a bad centrifugal switch, or a bad switch somewhere in the circuit, a bad capacitor doesn't behave like that ! Capacitors loose value over time or go open circuit completely, where as a switch contacts will arc and burn becoming intermittent before becoming completely open circuit.
    Sometimes you can smell the odd phenolic odour from a failing switch.
    Jul 2010
    9,088
    Hi Baron
    Well it could be if I had one, which I don't think I do.(though I haven't had the pump apart, so its just a guess. Haven't heard one)
    Wouldn't the type, V rating and uF of the cap indicate that it is a run cap not a start cap?
    It could certainly be a bad relay in the controller.
    Controller is harder to change as the manufacturers like to use different plugs between the controller and the pump, it goes without saying my spare pump has a different plug.
    I'm hoping the cap value went low enough to be the issue as I ordered a cap after my last post. I'll test the old one once I get it out. Thanks anyway. At least SWMBO thinks I am doing something
    6,436
    Hi Stuart,
    A cap start and run motor doesn't always have to have a centrifugal switch in there. However you will find out when you change the capacitor.
    Let me know how you get on.
    Jul 2010
    9,088
    Cap changed.
    New cap measures 12.27uF ESR 0.02ohm
    Old cap measures 1594nF ESR 0.34ohm
    The self healing must have given up
    Now to wait and see what happens.
  15. #15
    6,436
    Hi Stuart,
    Wow that capacitor has lost value, 1.5 uf nearly 1.6, the ESR has risen a lot by the looks of it as well.
    Thanks for the update.
  1. X and Y axis intermittent jamming
    By GeoffW1 in forum CNC Forum
    Last Post: 14th Sep 2016, 11:12 PM
  2. Washing machine pump as a coolant pump
    Last Post: 9th Oct 2015, 09:25 PM
  3. It's Stuart's Fault. An Optical Acquisition.
    Last Post: 4th Dec 2013, 12:48 PM
  4. dial fault
    By nadroj in forum THE HERCUS AREA
    Last Post: 27th Jun 2011, 12:00 PM
  5. intermittent arc
    By Bryan in forum WELDING
    Last Post: 22nd Jul 2010, 12:03 AM
