Results 1 to 8 of 8
    Apr 2012
    Healesville
    2,129
    Default Resistors, neon and suggestions please
    Hi fella's, is anyone up for solving a puzzle
    I am hoping someone can advise me on this circuit for my cylindrical grinder.
    I have a couple of questions, I have drawn a diagram in pencil of the circuit board in question and then colored the individual circuits using paint so I hope it is clear enough and understandable.
    It seems to me that the orange (positive) and black (negative) circuits are the timer circuit to adjust the dwell (time from wheelhead switch contact to energizing the valve solenoid).
    The large resistor mounted on the side of the control box has no wires connected and I think that it has been replaced by fitting a
    5.5 M ohm resistor to the pot, but I could be wrong.
    The top solenoid does not operate as the circuit is, I measured the voltage across the capacitor terminals and got a reading of about 65 vdc.
    The neon tube appears to be the only negative path to energize the solenoid, how does this work? That is until the mercury switch is tilted by the solenoid below and that is energized by the relay on this top solenoid.
    So it might need about 90 vdc for electron flow to create a negative circuit to the solenoid, looking at the circuit it gets the positive via the coil winding?
    Is this right? The wiring looks to be ridgey didge.
    So if this is how it gets illuminated it then supplies the negative to energize the solenoid?
    Do I need to reduce the resistance to get a higher voltage to excite the neon for it to work?
    Does the capacitor look like it would work ok given that the test reading is 10% higher that what is printed on it?
    If anyone has questions or needs clarification about anything here please ask as I really would like to get this old circuit running, I have had a look and found a timer that I could graft into the circuit but that will be my last resort if I can't sort this.
    cheers, shed
    6,444
    Hi John,
    A number of things stand out ! First the capacitor ! That is an oil filled paper capacitor. I wouldn't think that anything could go wrong with that, +- 10% in value is perfectly fine. A long as its clean and there are no oil leaks from any of the soldered seams, I wouldn't worry about it.
    The neon ! They can only support passing a very limited amount of current and do demand a series limiting resistance. Assuming that your circuit is correct the relay coil is being used to limit the current to it. I think that it is just an indicator which will extinguish when the relay is operated.
    The pot and resistors are part of the timing circuit but on your diagram don't seem to go anywhere. There would be a capacitor in there that would be charged up via the pot and resistor to create a time constant, (not a constant time). The very high values would suggest a low current circuit.
    What is the black thing with 8 terminals in the middle of your diagram ?
    HTH.
    Apr 2012
    Healesville
    2,129
    Hi John,
    HTH.
    Hi John, thanks for your reply, the neon is the only electrical (negative) path to the solenoid, there is no other way to energize the solenoid that i can see.
    The orange circuit/wire starts at 110 vdc then goes through the resistors and pot, then from there the reduced (about 65vdc) voltage/amperage goes to the large capacitor and solenoid. I think there might be too much resistance in that circuit to illuminate the neon? And I think that the neon needs to illuminate to energize the solenoid, as there is no other negative path.
    It is the wiring junction block, you can see the mercury switch wires attached to it
    6,444
    Hi John,
    Ahh right, terminal block, the penny didn't drop ! Give me a little time to study your circuit.
    As far a the neon is concerned, if it is the return path for that solenoid, the solenoid should operate when the neon strikes. I don't think that will work, somehow.
    Does the neon light up ? If so then it can only get a voltage supply via that solenoid. Yet according to your diagram that point is taken to negative via one of the mercury switches.
    You have shown the wheel head switch supplying a negative voltage to the other side of the neon.
    Can you confirm that the two relays (you have called them solenoids) have their contacts wired in parallel.
    The bottom relay doesn't seem to have a negative connection to its coil, unless it is via the valve switch.
    That capacitor seems to be directly across the entire power supply line. In which case use the negative terminal as the reference for all the measured voltages.
    I'm struggling a little because there are too many points missing.
    Apr 2012
    Healesville
    2,129
    Hi John,
    I bypassed the suspect resistor and adjusted the pot to 75 vdc output and put the neon globe in.....BINGO
    Yes that is correct, the top relay switches the negative to the bottom relay.
    Remember how early English cars had a positive earth and switches operated the negative, so this machine got the same design
    by the looks of it, so i guess you need to think a bit backwards
    It is switched by the wheelhead switch, so that circuit and the capacitor are only connected when the wheel head switch contacts the negative circuit. It looks to me that when that switch closes the voltage on the capacitor slowly rises (or quickly depending on how much voltage is coming in via the pot) and when the voltage gets to about 70 vdc the neon fires the relay, this close's the bottom relay which tilts the mercury switch and the negative circuit through mercury switch then "latches" the top relay at this point the valve lever solenoid is energized, it opens the valve and the valve switches and the head moves back and in doing so also breaks contact at the wheelhead switch.........well thats how i think it works.
    The reference to this in the manual is "The machine is fitted with a simple timer"
    Here is an 18 second vid of the xmas light https://www.youtube.com/watch?v=_K2W...ature=youtu.be
    I will put the control box back on the grinder and get the generator working and back on the machine then I will sort out what resistor is needed to replace the one currently on the pot.
    cheers, shed
    6,444
    Hi John,
    I'm glad that you have it working. I wonder if the DC generator is actually an AC one with a rectifier to produce the DC. The reason that I suggest this, is that the old time rectifiers died quite slowly with age, the output getting less and less.
    Assuming the relay coil is 4K and the supply voltage 100 volts, then V/R=0.025 amps or 25 milliampere, this is right at the limit for the maximum neon bulb current, for that type anyway. Circuit wise a little unusual.
    The resistor values need to be quite high in order to achieve any appreciable time delay given the value of the capacitor. RxC=seconds
    RC time constant calculator
    12 Meg = 120 seconds.
    Obviously I've rounded values here, but they won't be too far out.
    That big resistor I would guess is a quite low value and might be something used in conjunction with a motor.
    Did you manage to get a manual ?
    Apr 2012
    Healesville
    2,129
    Hi John,
    So far I have only taken a brush cover off and it had no continuity from the brush to the commutator, so I am guessing clean the commie and maybe new brushes, there is no reg.
    I originally worked it out using an online ohms law calc at 110v / 3.9 K ohms = 0.028 A or 3.1 W, but today after finding that the neon fired up at 70 v I revisited the online calc and got this, 70v / 3.9 K ohms = 0.01795 A or 1.25 W
    Do you think my figures are right? If so then things should be hunky dory.....[/QUOTE]
    I will revisit your time constant calc when I get to the resistor, it is something I have never heard of so it will
    be interesting, thank you for that, my plan was to get a maybe an 800 K resistor and suck it and see
    The reason that I want to wait until I get the generator power to the control box is that the voltage might be higher or lower
    than what i have now with the step down transformer and that might affect the resistor that I need.
    No, it only is in the pot circuit.
    Yes, I wrote a bit about it here... https://metalworkforums.com/f303/t19...97#post1954397
    Thank you for your input John
    cheers, shed
    6,444
    Hi John,
    Sorry, I do remember reading that post. I had forgotten about it !
    If you have a look at the the link I posted, it explains the time relationship R x C = seconds. Basically the higher the resistance the longer the time it takes to charge the capacitor. The neon bulb effectively sets the voltage level at which the relay will trigger. Which is exactly how using a neon as a voltage regulator works.
    70 volts will be close to the striking voltage of that neon. Until it strikes there will not be any current passed through it.
  1. Need suggestions for lubricant
    By rob streeper in forum METALWORK GENERAL
    Last Post: 6th Sep 2016, 02:05 PM
  2. Clamping suggestions please
    By jack620 in forum METALWORK GENERAL
    Last Post: 18th Mar 2016, 09:17 PM
  3. Test Bar Suggestions
    Last Post: 27th Jan 2015, 11:30 AM
  4. Helpful suggestions please
    By rogerjenkins in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 16th May 2011, 12:44 PM
  5. Suggestions please
    By artme in forum METALWORK GENERAL
    Last Post: 14th Jan 2009, 07:55 PM
