Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Apr 2018
    Drouin Vic
    634
    I can bring this thread to a happy, if slightly embarrassing, conclusion. Rather than shorting the windings when I replaced the internal connection wires, I had simply mixed them up. I went inside the motor again looking at the windings in preparation for stripping the thing out, and it occurred to me that I may not have correctly identified what went where. The little identifying tags on the old wires were completely illegible- I could just make out 'A2' on one of them but nothing at all on the others- and in my ignorance I had not labelled them when dismantling the motor. I had replaced the wiring with cores from some 3-phase flex, same colour wire across each phase with red heat shrink one end and white the other, to identify pairs and groups. Turns out I had one phase reversed, which became apparent when I looked more carefully at the furrows in the lacquer where I had dug the old wires out. I partially reassembled it and did a test run, it ran quietly with no smoke so I re-labelled the connectors and reassembled. Runs like a charm. I couldn't believe it wasn't cooked after the amount of smoke that came out of it with one phase reversed, but all the pairs had the same ohm reading and no shorts to ground so i seem to have dodged a bullet. So I'm as happy as a pig in mud, after quotes of '$450 minimum' and $600 from rewinders and several hours of daunting research on a DIY job. Thanks to those who have replied with helpful advice. If nothing else, I have learned a lesson about dismantling motors without making sure the wires are labelled.
  2. #17
    7,189
    Good to hear its working but if you've already let some smoke out I would at consider having a Megger (insulation) test done on it otherwise it could go anytime.
  3. #18
    Oct 2008
    N.W.Tasmania
    1,407
    I think that BobL has a point here, but if you speak with a motor rewinder, they may be able to just clean and revarnish the windings to basically make it like new again, worth asking about it anyway IMO. In any case I wish you good fortune with it whatever you decide.
  4. #19
    Dec 2007
    Adelaide
    574
    That's excellent news, good to hear you have dodged a bullet, while a diy rewind might have turned out a bit of an adventure - it's an adventure that is best avoided.
  1. Arboga EM825 motor rewind
    By WCD in forum METALWORK GENERAL
    Last Post: 26th Dec 2023, 09:19 PM
  2. gmf motor rewind
    By dodge at4 in forum ELECTRICALS
    Last Post: 24th Feb 2019, 04:03 PM
  3. DIY 3 phase motor rewind
    By bob ward in forum ELECTRICALS
    Last Post: 3rd Jan 2018, 09:59 PM
  4. Arboga mill motor rewind
    By familyguy in forum METALWORK GENERAL
    Last Post: 29th Aug 2017, 08:35 PM
  5. Have I cooked the motor?
    Last Post: 20th Dec 2016, 09:09 AM
