Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Bandsaw cutoff
    Jul 2011
    Adelaide
    837
    Default Bandsaw cutoff
    I have a Taiwanese 12 x 7 bandsaw sold through Hercus sometime in the 1990s. Today I finally got it working.
    The saw has the normal starter on/off buttons and a contactor so I was surprised by what happens when the saw reaches the end of its cut.
    As it reaches the end of its travel it pushes a toggle switch down which turns off the bandsaw. I would expect this to release the contactor in the same way as pressing the stop button but to my surprise toggling this switch back turns the bandsaw back on. I consider this dangerous. Has anybody else come across this weirdness in one of these saws?
    May 2011
    Murray Bridge S Aust.
    5,942
    Hi Eric, any chance of a pic of the switch and shut off mechanism please? If I remember rightly which possibly is wrong too, but the switch had 2 buttons one to start and one to stop, is this what you have?
    6,439
    Hi Eric, Kryn,
    I would have thought that the thing would have been wired in a "No Volt" configuration, where in the absence of the mains supply the contactor drops out and isolates the machine so that it cannot start up without pushing the start button.
    I assume that the toggle switch doesn't pop back up by itself in which case a normally closed push button may be better.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    My saw has not got a contactor, but does have the toggle switch that is pushed down at the end of the cut. Occasionally, when I lift the saw I discover that has not gone all the way down and the saw restarts (Not often these days - I think I have the adjustment about right now). It is certainly something to be aware of.
    If you have a contactor, wiring the toggle switch to cut the power to the coil would be an improvement.
    Jul 2006
    Athelstone, SA 5076
    4,255
    assuming start switch is momentary it is wired wrong in my opinion.
    should be a simple matter to correct.
    Jul 2011
    Adelaide
    837
    My thoughts exactly.
    6,439
    A simple diagram for wiring a No Volt switch.
    Sorry its a bit dark, found it on the net ! "A" and "B" are part of the contactor. The push buttons are the red and green ones.
    Jul 2011
    Adelaide
    837
    I inspected the electricals on the saw this afternoon. The no volt setup is wired as you would expect but rather than put the auto cutoff switch in series with the off button of the no volt setup it is in the line to the motor after the no volt switch setup. Which is what gave me the very unpleasant discovery that I could start the saw without pressing the start button.
    There has been a bit of cutting and shutting occurring in the past as there are some quite unorthodox connection methods employed. It is a fairly straightforward fix.
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Is this a dangerous thing outright in your opinion or only if you decide to play with the toggle while either setting a cut or holding your hand on the blade?
    6,439
    Working with or on any machinery that can start up unexpectedly is a hazard !
    Jun 2007
    sydney ( st marys )
    64
    4,887
    From my understanding of the original statement was that the machine did not start unexpectedly, the switch in question had to be intentionally reset.
    Jul 2006
    Athelstone, SA 5076
    4,255
    Quote Originally Posted by lamestllama View Post
    I can have a look at it for you if you are not experienced in electrical
    I can even bring that switch station over...lol
    Jul 2011
    Adelaide
    837
    Eskimo,
    Thanks for the offer but it is now fixed, I do still want that switch station though.
    Eric
    Jul 2006
    Athelstone, SA 5076
    4,255
    Eric
    I wont toss it
  15. #15
    Oct 2011
    59
    6,540
    I go past Eric's place most evenings on the way home from work. Happy to relay if easier.
  1. Recall on Swarts 14" cutoff saw, Jan 2017
    By GeoffW1 in forum METALWORK GENERAL
    Last Post: 12th Jan 2017, 10:13 PM
  2. bandsaw
    By shaper07 in forum METALWORK GENERAL
    Last Post: 23rd Aug 2016, 01:34 AM
  3. Makita Cutoff Saw (2414NB) - For sale
    By dradyz in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 7th Mar 2016, 09:19 PM
  4. Setting up metal cutoff saw table
    By dazzler in forum METALWORK GENERAL
    Last Post: 6th Jan 2011, 07:52 AM
  5. Power hacksaw vs drop cutoff wheel
    By RicB in forum METALWORK GENERAL
    Last Post: 7th Sep 2010, 12:12 AM
