Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 62
  1. #46
    Charlestown NSW
    65
    1,669
    Default Magnet Polarity
    I turned the magnet over this morning. It definitely has an effect. Not quiet what I was hoping for though.
    With it turned over the tacho didn't work at all. Just sat there displaying four Zero's.
    So I changed it around again.
    Its still fluctuating. Maybe its just a heap of crap. Most of the stuff I have bought from Banggood has been ok so I suppose I have to expect a dud occasionally.
    Here's a 30 second video I took this morning. Motor running at a set frequency.
    https://youtu.be/KUzLDjr0X5o
    Peter
  2. #47
    Oct 2004
    Glen Forrest, Western Australia
    62
    80
    Quote Originally Posted by bollie7 View Post
    Rick. That's interesting. I've mounted mine using an aluminium bracket, inside the change gear cover which is made from cast aluminium.
    When I first got mine I tried it out using a battery drill as a source of variable speed. BobL reckons that might not have been such a good idea.
    I have two of these so I think I'll put some time in and set one up a bit better for testing.
    peter
    Peter
    I tested all the connections, tried different power supplies and swapped sensors before making the new brackets. I think the sensors need to be isolated from everything
    Rick
  3. #48
    Charlestown NSW
    65
    1,669
    Quote Originally Posted by warrick View Post
    Peter
    Rick
    Rick
    thanks for the info. I'll try it out.
    peter
  4. #49
    7,183
    r
    That sounds very much like the problem I had when I accidentally touched the sensor wire with the power line - it means the sensor is cooked.
    You can buy spare sensors separately but make sure you purchase the right one - they are not all the same.
  5. #50
    Charlestown NSW
    65
    1,669
    I've got another sensor, I'll try it as well.
    thanks
    Peter
  6. #51
    6,439
    Hi Peter,
    Can you post a picture of the label on your sensor please.
    Also distance can be critical as well. You could build a test rig with a wood disc holding the magnet and run it in a drill press, then adjust the sensor distance to determine how far away it needs to be.
  7. #52
    7,183
    Most sensors have a red LED on the back of them and this lights up when the right distance is achieved.
  8. #53
    Charlestown NSW
    65
    1,669
    Hi Peter,
    I was going to do that tonight but I've had a big day and then with the predicted bushfire danger tomorrow, I thought it might be a god idea to clean the roof and gutters of my shed off when I got home from work. We live in suburbia and no large tracts of bush nearby (couple of Klms) but embers can travel a fair way so better to be safe than sorry.
    I've had a look through my pics but don't have a decent one. So tomorrow arvo hopefully.
    peter
  9. #54
    6,439
    Hi Peter,
    I only found out about the bush fires, from the news on TV today !
    Looking after yourself and family are more important than a picture ! I wish we could swap some of our rain for your dry weather for a while.
  10. #55
    Charlestown NSW
    65
    1,669
    Hi Peter,
    We are ok but there are plenty of others on this forum who could be (maybe have been) effected.
    The biggest problem for us is the smoke. If that's the only problem we have then I'll be happy.
    I feel for those who have last their homes and, with some, even loved ones.
    Its also pretty devastating thinking about the wild life (and domesticated animals) that have been killed. Then there will probably be some who survive the fire only to die of injuries or starve to death afterwards with nothing to eat.
    Edit. Sensor pics added. As the label is wrapped around the sensor Ive had to take four pictures so the info can be read.
    peter
  11. #56
    Aug 2011
    4,779
    Take care Peter.
  12. #57
    Oct 2004
    62
    80
    Peter,
    here is the bracket I made if this helps, The magnet holds itself onto the pulley (hasn't come off yet even at 3000rpm)
    I used a spare piece of smoke coloured perspex and heated it with a heat gun and bent it over a piece of timber, drilled my holes first
    Rick
  13. #58
    Charlestown NSW
    65
    1,669
    Take care Peter.
    Thanks Simon.
    We are not in a fire area, thankfully. The only advantage of living in suburbia. There are bush areas a couple of klms away but they are the sort of thing you get in scattered pockets. I do really feel for the poor buggers who have lost their homes etc though.
  14. #59
    Charlestown NSW
    65
    1,669
    Peter,
    Rick
    Thanks for the pic Rick. I might end up having to something similar with mine however I suspect I might have killed the sensor when I first got it trying it out. The first one I got everything was in chinese on it, so I think as I'm didn't know much about them, I probably wired it up incorrectly.
    peter
  15. #60
    6,439
    Hi Peter, Guys,
    Thank you for the pictures, I've not found any new information about them. I hadn't realised that there was a LED tell tale at the cable end. Simply waving a magnet around the front should cause the led to flash when power is applied. However if the led is faulty, you might be able to see a voltage transition on the output lead using a multimeter. If it doesn't then I agree its dead.
    The display should be OK though. I don't know of a simple way to test that, though I can tell you that it is identical to the one on the mill and that takes input from an optical slot sensor.
  1. Looking for tool advise
    By Lagair in forum METALWORK GENERAL
    Last Post: 6th Aug 2018, 09:23 PM
  2. Advise On Trailers
    By Christos in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 18th Feb 2018, 09:49 AM
  3. Very first TIG welds. please advise
    By Zumanity in forum WELDING
    Last Post: 9th May 2014, 03:28 PM
  4. advise need please
    By boyblueeye in forum WELDING
    Last Post: 13th May 2012, 12:22 AM
  5. Powdercoating advise
    By Geoff Dean in forum METALWORK GENERAL
    Last Post: 26th Jan 2006, 11:03 PM
