Results 16 to 30 of 62
30th Oct 2019, 08:15 AM #16Most Valued Member
- Charlestown NSW
- 1,673
30th Oct 2019, 08:46 PM #17Most Valued Member
- Charlestown NSW
- 1,673
BIngo - sort of. Tried it set to External 0-5V signal and away it went. However when the pot is turned back towards minimum the vfd stops before the pot has reached its full travel.
I measure it and the readings across terminal 1 and 2 (wiper) are 0.674 Ohm and across terminals 2 and 3 4.66K.
So maybe what it says on the diagram for the pot 1-5k means exactly that. A pot with a range from 1k to 5 K.
Ive just been researching potentiometers but as yet I haven't found any reference to one with a set range apart from zero to what ever the other value is.
Is such an animal available?
If not I'll have to make a mechanical stop of this one.
At least progress is happening.
Thanks BaronJ for the suggestion.
Peter
30th Oct 2019, 08:53 PM #18Member: Blue and white apron brigade
30th Oct 2019, 09:05 PM #19Most Valued Member
- Charlestown NSW
- 1,673
30th Oct 2019, 09:07 PM #20Most Valued Member
30th Oct 2019, 09:22 PM #21Most Valued Member
- Charlestown NSW
- 1,673
31st Oct 2019, 03:16 AM #22
Hi Peter, Guys,
Glad you now have it working
As Bob says, just stick a 1k resistor in the bottom end to raise it above zero, though I would have thought that reducing the speed to a full stop might be desired. Don't forget to put an insulating sleeve over the resistor, you don't want it shorting to anything.Best Regards:
31st Oct 2019, 08:16 AM #23Most Valued Member
- Charlestown NSW
- 1,673
Will do.
I will have all the controls in a box mounted to the headstock of the lathe.
Id prefer to have the pot not stopping the motor for two reasons. 1) the safety side of it. I can see a time when the pot has been used to stop the motor but the stop switch hasn't been pushed in (then forgotten about) and then the pot turned by accident (or design) and the motor starting again unexpectedly. 2) I want to keep the controls the same as what I already have on my mill.
Thanks for your help. I really appreciate it.
peter
1st Nov 2019, 07:34 PM #24Most Valued Member
- Charlestown NSW
- 1,673
Now I have proper lift off. The 1K resistor has done the trick.
Speed control is now good. Atm I've got the lowest frequency set to about 20Hz and the motor will run right down to that and still keep turning. No idea how that would be with a load on it but I don't intend to leave it set that low.
BobL and BaronJ. Thanks for accurate advise on this. Most appreciated.
Thanks to everyone else who also contributed their thoughts.
Hopefully this weekend I'll be able to make a start setting up the control box.
peter
3rd Nov 2019, 08:11 PM #25Most Valued Member
Hi Peter,
I'm late into this thread but read most of the posts to get to speed. I recently used one of these VFD's for my mill. It seemed I was unsuccessful at running the VFD with an external POT so I used the multisegment frequency selection.
When I tried to use the POT, I too saw what seemed to be a "random" frequency displayed on the screen. I was very odd. Fortunately for me I didn't really need the infinately variable speed and so discrete frequency selection was quite satisfactory.
I concur with you in that the manual is a little misleading.
Good luck with the POT!
I am undecided as to whether the cheaper cost of these VFD's (over a genuine HY) is worth the pain.
3rd Nov 2019, 09:22 PM #26Most Valued Member
- Charlestown NSW
- 1,673
At first I couldn't get the pot or multi segment working.
With help from BobL and BaronJ I finally figured out I was interpreting the book wrong. Once I set Pn03 to 3 "External 0-5V signal" the pot started working. It would shut the VFD off when wound back to miniuim though. Again with help from BobL and BaronJ I put a 1K resistor in series with the "ground" wire and it now runs as I wanted it.
Have you checked that setting on yours?
See above
Hearing you. If I had known before I bought it that it was not a HuanYang, I probably wouldn't have bought it. Live and learn.
I have a HuanYang on my mill with a remote pot which gives infinitely variably speed and I love it.
Peter
4th Nov 2019, 02:25 PM #27Most Valued Member
Sorry, thought I was all over the conversation!
Nth I lost count o f all the different combinations of parameter settings and wiring combinations so there's every chance I may not have tried what you ended up doing. I definitely didn't try a 1k resistor inline with the ground! Who would have thought of that!!!
Now that it's set up it works fine and it's as good as any other of my HY VFDs. But getting there was a PITA.
Mind you, you still got a bargain!
8th Nov 2019, 07:52 PM #28Most Valued Member
- Charlestown NSW
- 1,673
I've got the external control box wired, mounted and running. Just have to work out where I am going to mount the magnet and sensor for the Tacho now.
Still have to fine tune some of the settings but pretty happy with the install. Well worth the time and effort.
https://youtu.be/wSCWiecji0U
Peter
9th Nov 2019, 01:23 AM #29
Hi Peter,
Looking good !
I would not use silicon round that post ! I would use some felt or knitting wool pressed into the gap, then it can easily be removed if needed rather than trying to scrape away silicon filler full of chips.
Though about the only chips I can imagine getting up there, would be Brass. They seem to find their way into the most non intuitive places ! Having had to fight the zip on my jeans the other dayBest Regards:
9th Nov 2019, 10:19 AM #30Most Valued Member
That's nice. I do like the sound of that too. I would be interested in your feedback as to whether you get a better finish with a 3 ph motor. I have read that you can improve the finish purely by changing from a 1ph to a 3ph motor because they are smoother in running. Not sure how true that is but I would be keen to see what you think.
I have a 3ph motor waiting for my lathe. I may even buy another one of those isacon VFD's since I know how they tick now.
Looking for tool advise
By Lagair in forum METALWORK GENERALReplies: 8Last Post: 6th Aug 2018, 09:23 PM -
Advise On Trailers
By Christos in forum TRAILERS & OTHER FABRICATED STUFFReplies: 17Last Post: 18th Feb 2018, 09:49 AM -
Very first TIG welds. please advise
By Zumanity in forum WELDINGReplies: 5Last Post: 9th May 2014, 03:28 PM -
advise need please
By boyblueeye in forum WELDINGReplies: 8Last Post: 13th May 2012, 12:22 AM -
Powdercoating advise
By Geoff Dean in forum METALWORK GENERALReplies: 7Last Post: 26th Jan 2006, 11:03 PM
