Results 1 to 4 of 4
24th May 2019, 03:50 AM #1Golden Member
- Jul 2011
- 837
Dahlander wound motor reconfiguration
I have a 3 phase 415V Dahlander wound motor 2 speed constant torque motor. When in 4 pole configuration the windings are arranged delta with 2 windings in series between each phase. When in 2 pole configuration the windings are arranged into parallel stars with the centre points connected.
My plan is to reconfigure the windings to give me a delta arrangement such that between each phase there are two parallel windings. This should give me a 2 pole 240v three phase motor.
Unfortunately the ends of all the windings haven't been brought out to the connection box. I am wondering if anybody has had a look inside a Dahlander wound motor recently and can tell me if the ends of windings generally easy to get at?
24th May 2019, 08:31 AM #2Member: Blue and white apron brigade
- 7,188
I've done a few - it gets tricky as there are MNAY connections inside these motors so you have to be, comfortable with breaking a remaking more junctions than usual, and handy with a multimeter.
Here's a thread about a couple of such motors, WIring arrangements on a ∆∆/Y motor and it also shows what coil configurations/arrangements work and those that don't.
24th May 2019, 01:32 PM #3Golden Member
- Jul 2011
- 837
BobL I was hoping you would respond. Looks like you have already done what I intend to do with the parallel delta mode. I intend sometimes operating at 25hz so that vibration you got at that speed is a little concerning. It must be electrically induced or you would have noticed it previously.
I will let you know how I go.
24th May 2019, 05:35 PM #4Member: Blue and white apron brigade
- 7,188
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Three phase motor electric motor
By china eyes in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 5th Dec 2018, 04:02 AM -
Minor wound care
By Michael G in forum SAFETY FORUMReplies: 0Last Post: 22nd Oct 2016, 02:34 PM -
Is a motor start relay switch needed for a 3ph 2.8kw pump motor?
By Ben Dono in forum METALWORK GENERALReplies: 26Last Post: 14th Aug 2015, 02:38 PM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM
