Results 1 to 6 of 6
Thread: Mounting VFD on mill
20th Apr 2019, 05:12 PM #1Golden Member
- Apr 2018
- Drouin Vic
- 633
I'm approaching the completion of a fairly major project, mounting a Bridgeport J-head onto the overarm of my Victoria U2 horizontal mill. I have a VFD that I plan to use to run the motor; I have 3-phase from a RPC but seeing I have the VFD to hand I'll use it for the convenience of variable speed etc. I'm toying with where to mount the VFD, wondering how others have mounted VFDs on their mills. I have the DRO on an arm on one side of the machine, plan to put a panel with MachTach plus VFD controls on a similar arm on the other side, but not sure where I'm going to mount the VFD itself. How/where have others mounted theirs?
20th Apr 2019, 11:41 PM #2Most Valued Member
- Charlestown NSW
- 1,669
Pete
When I did my Bridgeport clone I used a cut down computer case to put the VFD and other electrics in and I mounted it on the right hand side of the column. It would probably need some sort of guard if I was going to be using flood coolant but at this point I'm not doing that so I haven't worried about it. I have a remote speed control pot, start stop switches and For-Rev switch mounted on the LHS of the head where the original forward reverse switch was.
Peter
21st Apr 2019, 12:02 AM #3Most Valued Member
- 5,945
Any chance of some pics of your mill, please?? I have a similar mill and wondering what else you have done to it.
21st Apr 2019, 01:02 AM #4Golden Member
- Apr 2018
- Drouin Vic
- 633
I'll put some sort of thread up when I complete the conversion, but here's a couple.
More than a few hours have gone into hanging that thing off the overarm, everything else has been neglected for several months. Getting close to running it now. I have the vertical attachment but the lack of a quill has been a major drawback.
21st Apr 2019, 01:10 AM #5Most Valued Member
- 5,945
I actually thought mine was similar, BUT it's that old, I think it was used to build the Titanic or maybe it was the Ark. I can't even find any pics of it on Google!!!!!
It runs flat belts and has a single overhead arm approx 60mm diameter, and a number3 morse taper!!!
21st Apr 2019, 09:08 AM #6Most Valued Member
- Charlestown NSW
- 1,669
DTI Mounting Arm
By jack620 in forum METALWORK GENERALReplies: 5Last Post: 14th Apr 2018, 12:49 PM -
Switchgear Mounting
By Anorak Bob in forum METALWORK GENERALReplies: 9Last Post: 2nd May 2014, 12:25 AM -
Mounting your VFD?
By bwal74 in forum METALWORK GENERALReplies: 10Last Post: 19th Jun 2013, 09:21 PM -
Schaublin Mill - Dividing Head Mounting Alternative
By Anorak Bob in forum METALWORK GENERALReplies: 23Last Post: 19th Dec 2011, 11:59 PM -
Mounting a DRO
By wafarmer in forum METALWORK GENERALReplies: 7Last Post: 1st Jun 2007, 09:18 PM
