Results 1 to 9 of 9
    Aug 2004
    Perth Western Australia
    65
    203
    Default Stuck light seal
    Ive broken a bulb off in my vertex work light.
    I need to pull the guts out and possibly replace the bulb holder.
    The problem I have is the seal surrounding the reflector is bonded to the body of the lamp.
    I tried to push a pallet knife between the seal and the body however the body is tapered and its well stuck.
    Perhaps some one can suggest a solution.
    Thanks Mark.
    I've become a tool of my tools.
    7,182
    Hot air gun - light application ??
    Aug 2004
    65
    203
    Default Thanks Bob
    A hot air gun sounds like a excellent idea.
    Thanks Bob
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Random thought - have you unscrewed the switch bezel from the back? While not necessarily so, there could be a bracket that the switch clamps between itself and the housing, giving the illusion of 'stuck'.
    Aug 2004
    65
    203
    Default stuck light seal
    I tried unscrewing the switch at the rear but that was not helpful.
    If I had pushed on the reflector would probably have broken it.
    I intend to make a jig so I can pull the seal outwards,then apply a little heat and see if that works.
    Thanks Mark.
    Aug 2004
    65
    203
    Got it! Heat pulling and tapping were to no avail, what I thought was a single seal turned out to be 2 steel rings fitted into grooves with the seal and reflector sandwiched between. My eyesight is not what it was.
    Not a easy task I was so relieved not to break anything.
    Now I will visit the 12 volt shop to get a replacement light fitting and bulb the original did not impress me after all if it broke once it could break again
    and HF want $14 per bulb.
    Mark
    7,182
    Quote Originally Posted by Poloris View Post
    Mark
    Have you seen my post where I replaced the globe with an LED?
    Aug 2004
    65
    203
    Default BobL's LED Post
    BobL I searched for that post but none of the key words I used gave me a positive result.
    Mark
    7,182
    Mark
    I think it’s in the WW forum. I can track it via image titles. Busy baby sitting ATM but can look for it later if you don’t find it in the interim.
    Here it is post #2
    Converting machine light to LED
  1. Seal Hunting
    Last Post: 3rd Nov 2017, 11:00 AM
  2. Electric motor oil seal, am I missing something ?
    By MasterSpoon in forum METALWORK GENERAL
    Last Post: 3rd Aug 2016, 08:43 PM
  3. T and C Workhead - Bearing Seal Stiction
    Last Post: 6th Jul 2014, 10:46 PM
  4. Slimline Seal Stub ID
    By Burnsy in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 29th Oct 2013, 08:47 PM
  5. Oil seal groove
    By philmc in forum METALWORK GENERAL
    Last Post: 12th Apr 2012, 10:47 PM
