Results 1 to 13 of 13
Thread: Interesting combined Mill/Lathe
7th Jan 2023, 06:24 PM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
I have always been intrigued by combined machines. Live tooling on a lathe, laser engraving head on a CNC mill, 3D print head on a CNC machining centre, et c.
In Australia, there was this "teaching" machine, the Adept CIM:
which I had thought about locating/buying. There is one up in the Blue Mountains.
..but the milling spindle only moves in the Z, thus not really a combined machine,
because you can't mill stuff in the lathe chuck.
So, a bit limited, and common sense prevailed.
Then, I just saw this on a FaceBook, in the "CNC Sales Australia" group:
https://www.facebook.com/commerce/li...4511297700573/
$5,500. Probably USD. And probably sans shipping.
I guess technically, it is just a router with an additional rotating C axis spindle, but I like that it is off the side away from the table!Last edited by nigelpearson; 7th Jan 2023 at 06:46 PM. Reason: images, words
Nigel, from a cave FULL of unfinished projects and lost tools.
7th Jan 2023, 11:02 PM #2Most Valued Member
That's a very nice machine.
I'm pretty sure a smart man like you, could build a unit like that.
When will the WIP reports start, and don't forget, plenty of pics please?
8th Jan 2023, 02:32 AM #3
That looks like a serious machine.
Having built a CNC milling router in the past, my advice will be to ensure the router is electrically/electronically in working order. No compromise in this aspect as this separates a working CNC mill from a pile of scrap.
9th Jan 2023, 07:29 PM #4Most Valued Member
Saw a video clip on making a mill for a small lathe and thought it may be of interest to someone.
Nowhere near as good, but for starting out it may be acceptable.
https://www.homemadetools.net/forum/...790#post215790To grow old is mandatory, growing up is optional.
9th Jan 2023, 09:40 PM #5Diamond Member
- Aug 2019
- 1,195
Thanks for that Kryn.
+ I like the way he has used the lathe chuck as the milling cutter holder.
+ Feed/lead screw for the carriage becomes power feed for X on the mill !
- The slotted table extends over the side of the small saddle rails.
A bit unstable - t'would rock the saddle?Nigel, from a cave FULL of unfinished projects and lost tools.
9th Jan 2023, 09:53 PM #6Most Valued Member
Where there's a will,
there's a rich relativeOops sorry wrong quote, there's a way.
Have seen on you tub where people have made a metal lathe also.To grow old is mandatory, growing up is optional.
10th Jan 2023, 04:41 AM #7Senior Member
- Aug 2021
- 46
- 117
Fascinating, a few things I would do differently though. But it looks like it takes light cuts at least.
I recently saw something (in the last few days) working on a similar principle. It was an attachment that may have been a commercial prototype from somewhere between the 50's to 70's or so by the look of it. It was an overhead attachment for a Southbend 9. Belt driven from the lathe spindle and then transferred to an overhead spindle. And attached to the bed in two places.
Thing I wonder about is the ability of the bed V ways to properly support the saddle considering the milling forces and vibration. And considering the dovetail slide is preferable for milling though linear slides also seem to work.
And the rocking of the saddle as mentioned by Nigel.
Further thoughts? Might be a cool thing to make for the fun of it and also for light milling jobs? But taking it easy so as not to ruin your lathe saddle.
10th Jan 2023, 12:21 PM #8
You mean something like this?
It was stated as a copy of the Target milling attachment and was sold by a British bloke who actively restores Myford lathes near Seaford SA.
The attachment appears to be centered by the tailstock, driven by the spindle and pivoted onto one side depending on the direction of rotation (based on my crude interpretation).
Here is a video showing the attachment in action (not showing any actual cutting):
https://www.facebook.com/raymond.mar...ibextid=W9rl1R
10th Jan 2023, 04:21 PM #9Senior Member
- Aug 2021
- 46
- 117
Interesting attachment.
The one I saw and mentioned earlier is this vertical attachment:
Looks very light duty but clever and interesting. Limited usage application but I kind of like it.
12th Jan 2023, 10:27 PM #10Most Valued Member
- Jul 2016
- 35
- 1,522
That one based on a south bend is really interesting. This is my odd multifunction machine, a UW1. It has some compromises but is a surprisingly competent lathe and mill (and a pretty average drill, slotter and saw (i don't have the saw bits)
It is best as a lathe though, and by a very long way, it has stops amd power feed on Z and X but X requires putting a gearbox on and a telescoping driveshaft and is not really worth the hassle unless horizontal milling.
Its also pretty pointless using vertically unless you need the last inch of negative Y travel.
13th Jan 2023, 02:39 AM #11
That's a brilliant machine tool, the UW1!
Here's one I once saw in the flesh nd thought it was the ant's pants:
http://www.lathes.co.uk/adcock&shipl...ation/img1.jpgCheers, Joe
13th Jan 2023, 09:12 PM #12Diamond Member
- Aug 2019
- 1,195
Adcock & Shipley combined machine
Wow Joe! Not just a combined mill/lathe, but also a drill press and surface/universal grinder.
I have never seen something so bizarre, because...
1) The various functions are obviously meant to all be used at once:
(by a team of white dust coat wearing operators )
I wonder if the work is passed clockwise?
From lathe to mill.
From mill to drill press.
From drill press to surface grinder.
2) The grinder is adjacent to the lathe.
In fact, it is slightly higher than the lathe bed,
so the grinding dust sprays onto it???
I guess a combined machine like this has the benefit of a huge heavy base,
for rigid machining stability, and could share coolant tank/pump.
It seems odd to me, though. Sort of like setting up machines in your workshop,
and having them fixed in that position forever without possibility of a re-org?Nigel, from a cave FULL of unfinished projects and lost tools.
14th Jan 2023, 11:36 PM #13
These machines were typically setup in ships' workshops, where space and rigidity could be an issue. I'm also not sure if the various functions could be used at the same time, white coats or not, because I believe some of the spindles shared motors - at least I thought they did.
Cheers, Joe
Interesting euro mill
By Hunch in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 2Last Post: 11th Jul 2018, 04:52 PM -
Another interesting option for lathe/mill motor replacement
By PDW in forum METALWORK GENERALReplies: 6Last Post: 20th Jan 2016, 09:30 AM -
Interesting Lathe-Mill Combination
By steran50 in forum METALWORK GENERALReplies: 18Last Post: 13th May 2012, 06:31 PM -
Al-280p Mill Drill Lathe Combined - Drawbar question
By Chela in forum METALWORK GENERALReplies: 20Last Post: 10th Dec 2010, 10:47 PM -
Combined Lathe/Drill/Milling machine
By iron bark in forum METALWORK GENERALReplies: 3Last Post: 4th Feb 2007, 04:09 PM
