Results 1 to 4 of 4
Thread: Controller WITHOUT a computer
24th Feb 2022, 02:52 PM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
From what I can understand, all the big machines, and a lot of little 3D printers/laser cutters/routers, have "offline" controllers. Basically, you load a G-code file from a serial port or USB stick, and it runs the program. Some of the little toy ones (GRBL), even if the power goes off - it will continue from where it was.
Some of the big machine's controllers also allow you to program simple shapes on the screen. I think it used to be called "conversational programming."
(which would be an apt name if they actually had speech recognition.
e.g. OK Google, machine a 50mm square from the current tool position )
Does anyone know if any of the cheap offline controllers have the same feature?
From a quick look on AliExpress, it seems some laser/plasma cutter controllers might:
https://www.aliexpress.com/item/4001355337648.html
"47 common graphics libraries (including grid graphics) with the option to set the tile size and hole size."
Anyone seen/used a controller (maybe with a touch screen, maybe function key menu) that does similar?
I'm thinking simple shapes like circle, square/rectangle, arc, ramp/slope/taper, flange, et c.
27th Feb 2022, 10:53 AM #2Golden Member
- Dec 2007
- 574
While looking for a CNC motion controller for my conversion I came across quite a few offline controllers that looked to be dedicated to CNC plasma cutters - all seemed to include a set of pre-programmed shapes, the Aliexpress link you included shows one that is typical, guess it depends on what you regard as cheap.
I weighed up the options - at the time there was not a huge amount of difference cost wise between a PC/Raspberry PI setup running Linux/Mach3/4 or an offline controller, I went the offline controller route, not having used a PC type setup I can't compare but can say my experience has not at all been bad, as a complete newbie, apart from some initial confusion on axis setup I had no problems getting my system working.
27th Feb 2022, 08:51 PM #3Diamond Member
- Aug 2019
- 1,195
Had to think about that. I guess under $700 delivered would be cheap to me,
mainly because a Masso controller is a little over $1000:
https://www.masso.com.au/product-category/masso-cnc-controllers
28th Feb 2022, 11:04 AM #4Golden Member
- Dec 2007
- 574
My M350 4 axis offline motion controller was $US427 inc shipping - came with the needed 2x24V power supplies and a MPG unit - what Aliexpress sellers don't mention is GST, you get the final total and then start thinking 'where did that extra $80 come from'. I haven't had a bad Aliexpress experience yet - an incorrect size stepper motor mount was shipped to me - only realised a few months down the track when I went to fit it - the seller did not argue and just shipped another.
MC-60 treadmill speed controller (controller needs a load ?)
By DenJon in forum ELECTRICALSReplies: 5Last Post: 1st Dec 2019, 07:49 PM -
SMS Computer Software
By electrosteam in forum GENERAL DISCUSSION / OFF TOPICReplies: 11Last Post: 4th Aug 2017, 11:50 AM -
Computer problems
By neksmerj in forum METALWORK GENERALReplies: 0Last Post: 11th Apr 2013, 08:26 PM
