Results 1 to 11 of 11
Thread: New Control Cubicle
16th Jun 2021, 10:15 PM #1Golden Member
- Apr 2009
- Kingswood
- 930
New Control Cubicle
On track to re-build the control enclosure, and revise the spindle controls, on my turret mill.
Spurred on by getting a Raspberry Pi running LinuxCNC (under test).
The existing control is a lash-up using an old Dell desktop computer running LinuxCNC and parallel port break-out board.
I am looking at a 600 H x 400 W x 250 D one from Elektron-BAAL on Ebay.
The enclosure will have, starting at the top:
- external E-stop button,
- air vent out,
- VFD braking resistor,
- 80 Vdc power supply,
- 2.2 kW VFD,
- stepper motor drivers,
- Mesa ethernet adapter card,
- Raspberry Pi,
- Low voltage power supplies,
- cooling fan,
- cable entries,
- air vent in.
Can anyone comment on the quality of items from Elektron-BAAL ?
Are there any other economical suppliers ?
Keep well,
John.
17th Jun 2021, 01:19 PM #2Golden Member
- Dec 2007
- 574
I thought about an electrical control box for my upcoming cnc conversion, but looking at the electrical control/meter box on the side of my house I see it is quite flimsy, I know there are better ones around so I will want to actually inspect before I buy, maybe those on Ebay are the better ones, if you go ahead perhaps report back on what they are like.
17th Jun 2021, 07:01 PM #3Golden Member
- Dec 2011
- 505
Hi John,
I'm also looking for an elec cabinet but could not find that seller or store name on ebay.
Please post a link if you have time.
Cheers, Bill
17th Jun 2021, 07:03 PM #4
The embedded and wall mounted meter enclosures here in The UK seem to be made from some kind of glass fibre reinforced plastic. There are metal ones around but are very expensive in comparison.Best Regards:
17th Jun 2021, 09:08 PM #5Golden Member
- Dec 2007
- 574
This is the seller he has a range of them.
Electrical Plastic Fiberglass Enclosure Switchboard Control Box 300x250x140 IP66 | eBay
17th Jun 2021, 11:08 PM #6
1st Jul 2021, 12:32 AM #7Member
- Apr 2020
- Hackham West
- 55
- 55
2nd Jul 2021, 04:57 PM #8Golden Member
- Apr 2009
- Kingswood
- 930
Bill,
Sorry I missed your request earlier,
Here is a link to Elekron-baal: https://www.ebay.com.au/usr/elekron-...p2047675.l2559
Keep well,
John
3rd Jul 2021, 12:46 AM #9
Just Iooked at this forum as you said you would be posting here.
I can give a honest review after buying one last month.
I wished I bought the Vevor (carbon steel?) brand on eBay.
They advertise as having a a 1.5mm cabinet over 1.2mm and a 2mm backplate over a flimsy 1.5mm I got in a 600x400x200 enclosure.
I was happy enough with the cabinet strength and finish, but the backplate flexes a lot, 2mm would have been a lot better.
Even using large mudguard washers in each corner it really needs a support in the centre.
The Vevor also comes with a coiled earth wire to the door.
So I would go the Vevor brand at only a few extra dollars.
If your on eBay plus look at it a few time and I usually see a $10 plus discount come up on the listing.
Sent from my 5007U using TapatalkUsing Tapatalk
3rd Jul 2021, 01:28 AM #10
I just looked and Vevor don't seem to have that size at the moment, and this one is really cheap enough.
It's why I bought mine from them.
https://www.ebay.com.au/itm/Electric...154756-20017-0
If you're willing to put a extra support bolt or something else like myself in the centre it will be fine.
I just find the 1.5mm backplate to flex a bit over the distance.
Maybe it's fine, but being a machinist I want everything rigid, lol
It's the first enclosure I've bought new and from eBay.
3rd Jul 2021, 11:05 AM #11Member
- Apr 2020
- Hackham West
- 55
- 55
A while back i was out of stock of a specific size enclosure so i bought a couple from the ebay supplier EB....honestly i was not happy with the quality of the boxes. Plus one was damaged so i sent them back. I did not review the purchase cause for some the boxes would do fine
RS485 VSD Control
By Stustoys in forum ELECTRICALSReplies: 25Last Post: 8th Apr 2020, 09:14 PM -
MMA holding the electrode for better control?
By topari in forum WELDINGReplies: 12Last Post: 29th Oct 2017, 06:26 PM -
Vfd control panel
By russ57 in forum ELECTRICALSReplies: 7Last Post: 29th Mar 2017, 01:19 AM -
Motor power with VFD control?
By jhovel in forum METALWORK GENERALReplies: 17Last Post: 20th Mar 2012, 12:44 AM -
distortion control
By Rinso21 in forum WELDINGReplies: 8Last Post: 7th Mar 2009, 02:25 PM
