Results 1 to 12 of 12
    Apr 2021
    USA
    2
    Default Best method to produce this little widget
    Hello Y'all
    Can anyone advise me on the best way to have these aluminum discs made, please -
    The diameter will be 2.25 inches and the height 0.75" The holes need to be bored to a depth of 0.5"
    The bores need to be drilled to a tight tolerance as the springs you see inserted are a push-fit.
    I'd be starting out with having some prototypes made, probably a dozen then larger production later once any kinks are ironed out. A low grade/ low cost alloy material is fine, there's nothing fancy about what these are doing, though they do need a fairly polished finish that's non-corrosive.
    I think ideally I'd like to make these myself initially. And I'd be OK investing in some type of desktop CNC machine if I knew what to look for and could find something under $1000
    But where would I source the aluminium/aluminum/alloy blanks cheaply enough?
    What type of machine (specifically, please) would I need to buy to do the holes? On the sample I have, the hole bottoms are flush/flat and are not tapered as they might be if drilled using a conventional drill bit, though this isn't an essential part of the spec if it inflates the cost.
    Can anyone help or even do this project?
    I'd also like to interchange the materials at some point and use either wood or acrylic blanks, so the machine purchased needs to be able to handle various materials.
    I've looked around for aluminum blanks but all I could find in this size were some super-fine tolerance discs that were fifty bucks a piece! I need to get these made for a couple bucks each.
    Thoughts, please!
    6,473
    Hi Rooze,
    Welcome to the forum.
    Do you have the machines that could make these parts ? If so then whilst CNC could do them it would probably be easier and cheaper to make them yourself, particularly if you want to use different materials at some point.
    This is how I would make them. Using a lathe part slices of material off to width from round alloy bar. Make a simple jig that can hold your round and be rotated and indexed to provide positioning for the holes. The centre hole can be done on the lathe before parting off. If there is only the spring in the hole, do you really need a flat bottom in it.
    Hope this helps:
    7,188
    To start with I doubt this is a task for a small desktop CNC.
    2.25" is a stock size for Al bar so you just need something to cut it to length.
    You would need a very large (ie 10's of thousands of $$) to hold longer lengths of this bar in a lathe
    OR
    You could use a small lathe and a small bandsaw to cut down short lengths of bar to hold it in the lathe chuck.
    The cheapest and quickest way to cut this material would be using a table saw with a negative raked blade. The stock has to be held firmly or it will spin as well as producing a poor finish.
    You could get away with a bench top saw to do this. The finish may not be to your satisfaction and then may need to be faced off using a lathe.
    The same table saw and blade combo will also easily cut acrylic and wood (albeit slowly)
    How many do you need to make, if its only a few the $50 a piece for the blanks is cheap especially if you have to buy machinery and get up to speed with use of machinery.
    You don't mention the diameter of the holes but a quick way to get a flat bottomed hole in Al is using a Forstner bit. However they only come in fixed sizes so the closet size might be too tight or too big. While Forstner bits can be used in a hand held portable drill, drilling large holes in Al is problematic as the pressure neede is very high so you will need a drill press
    May 2013
    Rockhampton, QLD
    68
    455
    Jul 2016
    35
    1,522
    There is definitely no $1000 machine manual or cnc that is going to do this job for you really. Unless you get very lucky. Manual mill with a divider and a good horizontal bandsaw that cuts straight is probably your cheapest option.
    Anything CNC even an old fadal or hass you may as well just light 10k on fire now.
    Id say produce them manually for now or outsource them.
    Aug 2010
    Toorloo Arm, VIC
    39
    1,290
    Quote Originally Posted by caskwarrior View Post
    Might be. Poster is in the US, as you know it's a whole different world of machine tool availability over there depending on where exactly they are.
    But producing them in aluminium for a 'couple of bucks each'? That might be a tall ask even in USD, without outsourcing to China, unless you get a massive run done by a CNC company. Looks like online (probably close to off the street price) for 2.25" 6061 bar is about $35USD per foot, which works out to about $2 USD per 3/4" before you even start machining. 2000 series aluminium might be cheaper, but looks like it also might be a less common stock item from the brief look I had.
    For prototyping in aluminium, pick one of the many hobby machinist boards with a far higher US population than here (Probably 95% of active members on here are in Australia, not much good to you), and ask for someone to do it there. Someone with a lathe and a mill can knock them out FAIRLY quickly, but it's still going to cost you. I figure an absolute bare minimum of 15mins each for me to make them here once in the rhythm, that's bandsawing solid stock to rough length, face both sides on the lathe and centre drill, then punch the hole pattern out on the rotary table on the mill using a centre cutting endmill to give the flat bottomed hole. Add a bit of time if the outside diameter needs to be cleaned up too, and add more time for every tight tolerance. And given things often take longer than I think they're going to anyway....
    If I had a big enough spindle bore to pass it, could skip the bandsaw step and turning the OD would add a lot less time - if you're lucky enough, someone local to you will have a big old Monarch or Pacemaker (or one of the various other big old American iron) with a big enough spindle bore to pass it through. Although, thinking about it, the Graziano has a 2" spindle bore with some form of taper in it, could probably jam about 12" of 2.25 stock through the chuck before the taper got too small, and with a 2.25 OD could probably get away with at least another 6"-8" hanging out the front, so might be able to bypass most of the bandsawing for the dozen desired with a 2" spindle bore, which is going to be a LITTLE easier to find.
    Of course, given you mention you want to make them in wood or acrylic later anyway, 3d printing in plastic would probably be the far cheaper way of prototyping them, even if you buy yourself a 3d printer to do it...
    Apr 2021
    USA
    2
    Hey, thanks y’all for some great feedback. I wonder if there’s some way to cast these as a cheaper option.
    I’ll check that out next
    6,473
    Hi Rooze, Guys,
    I rather suspect that casting would be a more expensive and time consuming method of production ! That is unless you are going to go for Die casting, producing millions, in which case Mazac would be the material of choice.
    Some years ago I went through a not dissimilar process. I had to produce several thousand aluminium discs, 100 mm in diameter 12 mm thick. I found that the most cost effective way to produce them was to trepan them from squares of plate cut to just over 100 mm, actually 110 mm if I remember correctly. Trepaning was far faster than using a hole saw.
    The following process saw 16 drilled and threaded holes around the edge of the disc. The was a countersunk hole in the centre of the disc as well.
    Each disc took about three minutes to produce ! I wouldn't be surprised if producing your widget took about the same time.
    Production is all about cost ! Time is money and labour isn't cheap !
    Dec 2007
    103
    Try one of the online services - just upload a file and you will get back some indicative pricing straight away.
    https://www.xometry.com/
    34
    1,079
    Don't wanna be to be 'that guy', but it's time for a reality check. This is going to be blunt, sorry.
    Starting from the end of your question.
    Quote Originally Posted by rooze View Post
    Not gonna happen. End of story. The rough material cost ALONE is gonna be at least double that before you even think about machining it
    You'd want to be holding a half thou tolerance on that, drill and ream would be the DIY method to get that.
    Again, not gonna happen. Accuracy is expensive. Plus, you'll need to machine the blanks out of bandsawn bar stock first, so you'll need a lathe as well.
    You can't.
    Ya. Material + programming time + setup time + machining time + tooling + overheads + hourly rate of the guy running it = hand over the credit card.
    Aug 2019
    Revesby - Sydney Australia
    57
    1,195
    Howdy Rooze.
    Someone in China could churn them out for a couple of bucks a piece, but I suspect best USA prices would be $8 to $10 each?
    Also,
    A) Non-corrosive is a challenge. Is it used in something caustic? (which might require Anodising)
    Or are you talking about the springs not rusting into place?
    You could use really cheap Aluminum (e.g. commercial quality Aluminum stock), but it will look blotchy when anodised.
    B) How well does the disc have to grab the spring? If it is a very close fit, assembly will be a challenge. A drop of Loctite in the pocket might be easier
    Anyway, If the spring diameter is close to a standard size, I would try prototyping on a lathe (CNC or otherwise), with live tooling. 14 steps;
    1) Face the bar.
    2) Lock spindle. Load drill, or centre-cutting end mill, in live tooling. Turn on coolant.
    3) Wind cross slide to back pocket radius. Plunge back spring pocket.
    4) Wind cross slide to middle of bar. Plunge middle spring pocket.
    5) Wind cross slide to front pocket radius. Plunge front spring pocket.
    6) Unlock spindle. Rotate 60° and lock again.
    7) Plunge spring pocket.
    8) Unlock spindle. Rotate 60° and lock again.
    9) Plunge spring pocket.
    10) Unlock spindle. Rotate 120° and lock again.
    11) Plunge spring pocket.
    12) Unlock spindle. Rotate 60° and lock again.
    13) Plunge spring pocket.
    14) Load parting tool. Use it to skim outside of bar, and then part disk off at 0.75"
    (and if you are using a CNC lathe, either trigger bar feeder to push through more stock, or trickily use the parting tool in two steps, and use a brass sheet in the slot to slide stock along before parting off)
    I'm sure a better machinist could improve my steps, but I hope that will give you an idea?
    6,473
    Hi Nigel, Guys,
    I've done that with pocketed springs, the tolerance can be quite loose ! Twisting the spring like a screw as its placed in the pocket causes it to grip the wall in the pocket.
    Actually similar devices are commonly found in clutch mechanisms !
  1. Machinist wanted to produce axle
    By wheelinround in forum METALWORK GENERAL
    Last Post: 17th Jan 2021, 11:15 AM
  2. What would be the best method to fix this?
    By Zumanity in forum WELDING
    Last Post: 15th May 2014, 09:02 AM
  3. Honing method
    Last Post: 14th Aug 2013, 10:02 AM
  4. Asking for someone to produce a piece of work - acceptable?
    By Manaz in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 7th Oct 2007, 06:48 PM
