Results 1 to 9 of 9
17th Feb 2021, 06:25 AM #1
New Member
- Feb 2021
- At work
- 5
Building CNC plasma/Mill Combo and 2nd Router
Hello guys ,
I will like to share my work . Im making 2 CNC machine one will be 2.4m x 1.5m and will be combo Plasma and Mill is made of old stile 100x100mm profile.
Second CNC will be just router 5-6 axis with tools changer made of 80x80 .
I will try to test all best controllers for my needs . Stay tune and let me know what you think about it ... Thanks guys ..
20200801_193640.jpg20200801_193652.jpg20200801_193711.jpg20200812_195921.jpg20210203_112742.jpg
17th Feb 2021, 01:16 PM #2
Hi Weld ON,
Welcome to the MetalWork Forums,
Your U tube link was deleted as it is not compatible.
This forum is mainly Aussie-centric as it originated in Australia and most of our members are Aussies with a smattering of members from elsewhere around the globe. We have some fine folks here who are supportive friendly and helpful.
Please take the time to navigate around the forums to view the varied and interesting subjects.
To do this, goto the the FORUM box in the top left hand corner of the screen. Click Forum Home and a scroll down page will come up.
Scroll down the page and the various help pages and sub forums shall be shown.
Please read the Terms of Use on the very top of the scroll down page - they are our rules.
To save time heres the link
https://metalworkforums.com/f90/t197...terms-tou-read
Many pages also have a sticky at the top.If you post its always a good idea to check the sticky ,if there is one there.
Please post your questions in the appropriate MetalWork forum. Can I ask that you change your location? Sometimes it is handy for responders to know where a poster lives in giving advice about products or services.
Again, welcome to our forums.
17th Feb 2021, 06:48 PM #3
Senior Member
- Oct 2015
- melbourne
- 384
Looks like a solid start.
Where abouts are you..
18th Feb 2021, 10:29 AM #4
Novice
- Oct 2012
- Wallerawang NSW
- 14
Plasma cutting is messy.
Hi Weld ON
I have built a cnc plasma cutter and would like to let you know that the process makes a lot of mess.
Combining a mill into it would mean a lot of cleaning every time you want to mill something.
Are you thinking to have the plasma table on top of your milling surface?
If you are going to have a water table (which I highly recommend to catch most of the crap) they are heavy even if you drain them. The mess they produce is abrasive and gritty - not something you want any where near a mill.
I think you might be better off having one or the other.
19th Feb 2021, 06:48 AM #5
New Member
- Feb 2021
- At work
- 5
To Grahame : Thank you very much for your help . Ok , i will have look i try my best ..
To russ57 : thanks , Netherlands
To Wallerawang : I need mill because sometimes i need to get nice hole or shape , so first with plasma and get nice look with mill and continue with plasma .
Im welder so i know how bad is plasma cuttingMilling head will get cover and i will use only when required. First im going to build cnc plasma and there will be option to add mil head. If you can stay tune then you will see how i can manage my new projects ..
Thanks guys and now you can check my channel and some of other pictures ..If you could watch,like, subscribe please and thanks ... will help ..
https://www.youtube.com/channel/UCNm...7ql2bQg/videos
https://youtu.be/NZINdgYYHD4
https://youtu.be/HXLN-BrXmoI
https://youtu.be/Y3CbDbcLvHo
25th Feb 2021, 08:11 AM #6
New Member
- Feb 2021
- At work
- 5
some more pic ..
25th Feb 2021, 02:57 PM #7
Most Valued Member
- 54
- 1,514
Looking good.
What is the overall gear reduction there - about 25:1 ?
What max travel rates are you expecting in plasma mode
25th Feb 2021, 08:16 PM #8
New Member
- Feb 2021
- At work
- 5
Hi Steve , thnaks for your interesting ..
High resolution 3.2:1 belt drive reduction for NEMA 34 motors motors
I dont know yet , i need to test , but im going to use closed loop motors and frame is heavy 220kg so i will be able to run on hight speed , we will se when done ..Stay tune , more of project , welding and CNC stuff will be posted on this lovely formu ,,,
25th Feb 2021, 09:19 PM #9
Most Valued Member
- 54
- 1,514
Thanks.
For some reason my brain saw a double reduction gearing setup - which it obviously isn’t when I look again now!
WHo here has a CNC mill (not router) with a 350mm diameter envelope?
By jhovel in forum CNC ForumReplies: 2Last Post: 6th Jun 2020, 12:06 PM -
Using a CNCEST 6040 CNC Bed Mill/Router - My first foray into CNC
By kwijibo99 in forum CNC ForumReplies: 1Last Post: 22nd Apr 2019, 07:35 PM -
TIG / Plasma Cutter Combo or separate units (<1000 dollar)
By Dodulation in forum WELDINGReplies: 3Last Post: 3rd Jan 2019, 02:52 PM -
router bits in lathe to mill aluminium - youtube video
By steamingbill in forum METALWORK GENERALReplies: 3Last Post: 29th Oct 2013, 06:55 PM -
Lathe/drill/mill combo. or AL-320G
By KevinR100 in forum METALWORK GENERALReplies: 4Last Post: 1st Mar 2007, 12:56 AM
