Results 1 to 3 of 3
    Dec 2020
    Geelong
    7
    Default Hobby DIY CNC Mill & Plasma Cutter.
    Hi All. Thought I'd post some videos of my DIY CNC Mill / Plasma Cutter. I'm just adding rotary pipe cutting or at least trying too.
    And my first cut of a sign.
    Im using 2 x Gecko G540's on two parallel ports. DIY controller box. When I'm not metal working the water tray lifts off the back of the table and my spindle fits in where the plasma torch sits. My table surface sits on raills and 4 allthread rods so I can lower the raise the cutting surface. So I've a deep Z axis.
    Brad.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Nice work
    Dec 2020
    Geelong
    7
    Hope this is helpful for someone.
  1. Plasma cutter ?
    By morrisman in forum WELDING
    Last Post: 20th May 2017, 08:22 PM
  2. Big new plasma cutter
    By PDW in forum METALWORK GENERAL
    Last Post: 5th Feb 2017, 10:19 PM
  3. Plasma cutter
    By clive hugh in forum WELDING
    Last Post: 2nd Nov 2015, 11:43 PM
  4. Plasma cutter
    By Marc in forum METALWORK GENERAL
    Last Post: 28th Mar 2012, 08:37 PM
  5. CNC Plasma Cutter.
    By the_duke in forum METALWORK GENERAL
    Last Post: 12th Jan 2010, 01:32 AM
