Results 1 to 15 of 20
Thread: Ballscrew Axial Backlash
9th Aug 2020, 07:46 PM #1Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
The drive end should have thrust bearings or angular contacts. That bearing in the drive end is just a deep groove ball bearing and is just holding the screw up.
9th Aug 2020, 08:34 PM #2Golden Member
- Apr 2009
- Kingswood
- 930
Thanks for the comments.
My non-drive end is not supported by a bearing.
It is a 32 mm screw so pretty stiff and I have not observed any whipping.
The drive end (I think !) is a deep groove ball bearing, which could be the problem
A strip down will check that the assembly is correct and tight.
There is a multitude of solutions for bearings with controlled/limited axial movement.
I am just seeking comments from others as to what they selected, and why they made that selection.
At 300 mm/min my 10 mm pitch x-axis screw is only turning at 30 RPM.
I think I can ignore all bearing speed ratings and temperature effects and concentrate on the bearing room-temperature static ratings.
But, price/performance comparisons are difficult.
Bearing selection appears to be a black art !
Keep well,
John.
10th Aug 2020, 01:51 AM #3
Given that you only have one bearing on your ballscrew, I would replace it with either a 4-point contact bearing, a double angular contact bearing or - if you can find the space - a pair of angular contact bearing. In any case, it can't be a deep groove ball bearing in the long run: your axial float will get bigger and bigger as the balls and tracks wear.
Cheers, Joe
10th Aug 2020, 07:48 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
wouldn't get to worried about load ratings, more critical is what will fit in the available space. If you let me know what bearing it has and some pics of the mount i can make some recommendations.
11th Aug 2020, 10:02 AM #5Golden Member
- Apr 2009
- Kingswood
- 930
snapatap,
Thanks for the offer to help.
You are correct on the question of space available.
Correction to the OP:
the suspected bearing is 6204, not 6207.
My investigations lead me to a 7204 bearing pair as a selection.
The pair is 14 mm longer than a single 6204.
I will do a sketch of what I think is the assembly later today and consider appropriate alterations.
This could include boring out the table end cap to accept a bearing sleeve 14 mm longer than existing.
Then boring out the pulley to accept the extended bearing length.
A couple of questions:
a) How does one get the correct preload on 2 x 7204 bearing stack ?
I assume a manufactured selected pair of 7204 bearings with, say, 25 micron end float is out of my price range.
I have a good surface grinder and the patience to go through a few make-install-test cycles to size any spacers required.
b) Would a duplex ball arrangement be 'good enough' in this application ?
Keep well,
John.
11th Aug 2020, 10:31 AM #6Most Valued Member
- 2,666
Precision angular contacts would be absolute overkill for the application as you don’t need the precise radial location/support that they provide.
Adding thrust bearings (even a single and preloading the existing bearing to remove clearance) might be all that is needed - but as already said it’s all about what’s practical with your particular installation.
11th Aug 2020, 06:15 PM #7Golden Member
- Apr 2009
- Kingswood
- 930
Learning a lot about bearings.
Now know the correct term is 'double row', not 'duplex' as mentioned previously.
And that a pair of angular contact bearings can be arranged either 'front-front' or 'back-back' for different performance characteristics.
Got out the handbook for the original (manual) build of the mill.
The leadscrew drawings for the X-axis and Y-axis show 2 x 6204 bearings.
The drawings do not seem to include any special shims for preloading.
I wonder if the factory purchased matched pairs of deep groove ball bearings, and the pairing has been lost over the years.
Perhaps all I need to do is sort out the pairing !
Put the DI on the end of the ballscrew shaft with steppers de-energized.
Can rotate the pulley CW and CCW and see 0.1 to 0.15 mm end float on the DI.
Did the same thing to the Y-axis and got about 2/3 the movement.
This means I have an easy way to check any new trial assembly.
There is a large spacer between the nut and the pulley, so re-arranging to fit shims in the bearing stack may not be too difficult.
RS Components list a NSK 7204 bearing for $30, so not too expensive.
Keep well,
John.
11th Aug 2020, 06:59 PM #8Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
A. for this application spacer between the outer races, threaded shaft with nut, just like car wheel bearings, no need for high precision bearings
B. Assume you mean 2 deep groove ball bearings? maybe but i would rather angular contacts.
What sort of mill do you have? I wonder if someone has put 2 deep groove ball bearings in the housing instead of a pair of angular contacts.
11th Aug 2020, 08:21 PM #9Golden Member
- Apr 2009
- Kingswood
- 930
The mill is a Spanish Kondia Fv-1.
A good solid close clone of the Bridgeport, seems to work Ok with CNC.
The Kondia manual drawings look like 2 x deep groove, and the parts lists them as 6204, deep groove.
Tomorrow I will make some test shims to see if that approach will work.
Prefer cast iron, but at ( say ) 2 mm thick may be too fragile.
My surface grinder has a DRO with 10 micron resolution, so differential shim sizing can be achieved.
When the disassembly occurs, I will check the fitted bearings if they have any orientation markings.
I have sensitive dial indicators and a surface plate, might be able to detect any special inner/outer ring grinding.
Keep well,
John.
11th Aug 2020, 09:34 PM #10
Have a look for a 3204. It's a single bearing with two rows of angular contact balls and races and only 20.6mm wide (6.6 more than the original - and no preloading needed. All done internally at the factory.
Cheers, Joe
12th Aug 2020, 10:42 AM #11Golden Member
- Apr 2009
- Kingswood
- 930
The 3204 bearing is the double row type I was referring to.
Pricing is not too bad, but trying to ascertain the axial float rating is a bit difficult.
A SKF table quotes C2, C3 etc as referring to axial internal tolerance.
I assume this is the float.
But one commercial source quotes C2 as 'less than normal radial clearance'.
When I re-balled the X-axis nut, my assessment was about 25 micron axial float, so another 25 micron from the bearing would total 50 microns.
A friend is an expert machinist and he suggests I have a chat with his preferred local bearing supplier.
2 x 6204 is 28 mm wide, a single 3204 is 20.6 mm, and the difference can be accommodated with an additional mounting sleeve.
Keep well,
John.
13th Aug 2020, 04:42 PM #12Golden Member
- Apr 2009
- Kingswood
- 930
Got the bearings out, 2 x labelled PFI 6204-2RS C3.
One net supplier lists the PFI bearing 'C3' as greater internal clearance.
There was a punched (as in burred) shim between the outer rings.
The burrs curve over the ring chamfers without adding to the thickness (but make it hard to measure).
Best estimate of the shim is 100 microns, measured directly with a micrometer and as added to a bearing outer.
Bearing 1:
- outer 13.97 mm,
- inner 13.975 mm.
Bearing 2:
- outer 13.98 mm,
- inner 13.96.
Holding bearing in the hands, one can detect looseness, not sure if pure axial or just twist between the rings.
To sort out the axial/twist question I would have to get a precision block to support the inner on a surface plate.
Then press the outer down and test the height of both rings off the table.
But:
- one bearing has the inner ring thinner than the outer by 20 microns,
- the 100 micron shim for the outer is the wrong way,
- I wonder if a shim for the inner has gotten lost ?
- deep groove balls just seem the wrong selection.
So, still considering a replacement.
As everyone always wants photos, attached is my obligatory non-informative contribution.
Keep well,
John.
13th Aug 2020, 04:50 PM #13Most Valued Member
- 2,666
Given you’ve got a surface grinder you could always just grind a smidgeon off the side of one of the outer races to create some preload.
14th Aug 2020, 12:18 AM #14Golden Member
- Apr 2009
- Kingswood
- 930
Steve,
Grinding is tempting.
I could put the bearing on the table with the 100 micron shim under the outer ring.
The inner would be sucked down to the chuck, leaving the outer somewhat higher.
A grind right over would leave the outer width less than the inner width (up to 100 micron difference).
Then assemble the pair without the shim -- tempting !!
Keep well,
John.
14th Aug 2020, 02:11 PM #15Golden Member
- Apr 2009
- Kingswood
- 930
Developments this morning.
I have a nice benchtop inspection DI with a Mercer 0.0001" indicator by Arthur Murray in Melbourne.
Put the bearings on the anvil, can can pick the differences in the thickness of the rings noted earlier:
(A) inner high by about 2.5 microns (approx 1 div),
(B) inner low by 18 microns (5 - 10 div).
Tried adding the shim between the bearing and anvil, and pressing the inner down flat:
(A) inner low by 75 microns (approx 30 div),
(B) inner low by 75 microns ( 30 div).
Found a gauge block that spans the inner and not the outer.
The small set of gauges I have is Mitutoyo, and the blocks are only general purpose ground on the non-gauge sides, so had to micrometer select one that was parallel.
When tested in the DI, can easily pick up the inner being higher by something like 30 to 50 div, but not reliable because the outer ring would rock around.
I will repeat all the above with a fellow machinist this afternoon as a check.
It is easy to see why I was getting such a large backlash on the mill.
Keep well,
john.
CNC Turret Mill - Ballscrew Covers
By electrosteam in forum CNC ForumReplies: 7Last Post: 13th Feb 2020, 11:45 AM -
Ballscrew Nut Re-fit
By electrosteam in forum CNC ForumReplies: 31Last Post: 23rd Oct 2019, 06:59 PM -
Axial Fan
By eskimo in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 4th Jul 2019, 10:30 AM -
Co-axial indicators
By simonl in forum METALWORK GENERALReplies: 31Last Post: 13th Sep 2017, 10:25 PM -
Ballscrew Run-out
By electrosteam in forum METALWORK GENERALReplies: 11Last Post: 17th Jan 2011, 07:38 PM
