Results 1 to 4 of 4
25th Jul 2020, 12:19 AM #1Novice
- Nov 2019
- Canada
- 14
4 Types of End Mills to Make your Machining Process Easier
Generally, there are four different kinds of end mills that are used in sync with the end-product desired. They are:
Straight Flute
As the name suggests, these end mills have ‘straight’ and basic flute and are best for general use. They are also widely popular for their good edge quality.
Up-cut and Down-cut End Mills
They are spiral tools that either carry the residue chips up and away from the designated area, hence giving it a somewhat rough finishing, or take them down for a smoother top finish.
Ball-nose Mill
Ball-nose mill has rounded tips that are ideal for 3D tooling as they produce some high quality carved surfaces.
V-bit
Generally used for carving a V-shaped depression in the material, v-bit end mill comes in two forms- 60° or 90° V-bit. The sharp tip of the tool is used to cut through the narrow paths whereas the wider bottom is used to create larger cuts. This tool is also ideal when one wants exceptionally sharp edges, unlike the other end mill tools.
Pro tip: If you want even better finish for your material, go for end mills that are tipped with solid carbide.
25th Jul 2020, 09:54 PM #2Gear expert in training
- 34
- 1,080
Thanks for the copy/paste. It's also not particularly accurate.
Straight flute is NOT best for general use, spiral is almost always superior.
Up spirals don't leave any rougher finish than down spirals
26th Jul 2020, 09:42 AM #3Philomath in training
I agree with Elan. It reads like it was taken out of a woodworking text about CNC routers.
26th Jul 2020, 01:50 PM #4Gear expert in training
- 34
- 1,080
Given that all he does is post completely vague questions then never returns to the thread, I'm suspecting he's a bot or somehow trying to generate clicks somewhere...
Little Hoggers = Face Mills or end mills ?
By steamingbill in forum METALWORK GENERALReplies: 10Last Post: 21st Dec 2019, 09:51 AM -
Looking to make dapping in quantity easier
By dhenry in forum JEWELLERYReplies: 7Last Post: 11th Feb 2019, 02:44 AM -
Multi Process Welders
By jennydavies77 in forum WELDINGReplies: 3Last Post: 18th Nov 2013, 09:35 PM -
Does Machining Make You Tired?
By Jarh73 in forum METALWORK GENERALReplies: 19Last Post: 13th Apr 2011, 09:40 PM -
blackening process
By tanii51 in forum METALWORK GENERALReplies: 4Last Post: 4th May 2009, 08:46 AM
