Results 1 to 6 of 6
    Nov 2019
    Canada
    14
    Default CNC down need new stepper motor
    I am having an issue with a stepper motor on machine that I bought used 6 years ago. The company that makes it is out of business and I need to find a replacement. Most new NEMA 34 motors are using a 1/2" shaft and this one has a 3/8" shaft. I do not mind a bigger motor as I have plenty of space and have updated Gecko drivers but need to work with the pulleys and belt size I have. Here is the info I have.
    Current Motor
    MCG IH34110
    Does not need shaft on both sides as only one is used.
    Pully
    3/8" ID with 7/8" OD .080 pitch
    Any recommendations on motors and or pulley combinations would be great.
    6,475
    Quote Originally Posted by NGrimberg View Post
    Current Motor
    MCG IH34110
    PullyAny recommendations on motors and or pulley combinations would be great.
    Hi Norman,
    Does this help ? Watch out for wrap !
    https://www.ebay.com/itm/MCG-IH34113...-/291961776343
    Aug 2019
    Revesby - Sydney Australia
    57
    1,195
    Left-field idea:
    1. Bug cheap NEMA34
    2. Find someone with a cylindrical grinder (or a toolpost grinder on a lathe), and grind shaft down?
    Sep 2006
    Australind , WA
    58
    1,281
    Machine the pully out to 1/2"?
    Oct 2015
    melbourne
    473
    Room for an adapter 1/2 bore one end, 3/8 shaft at the other?
    Much easier to go the other way...
    Jun 2016
    Sydney
    283
    Bore out pulley. Not hard, and pulleys are cheap.
    Mounting the pulley so it is centred is key. Use existing hole as a guide.
    Roger
  1. Stepper motor for a power drawbar?
    By j3dprints in forum METALWORK GENERAL
    Last Post: 5th Feb 2018, 05:23 PM
  2. What limits stepper motor speed?
    By Sterob in forum CNC Forum
    Last Post: 6th Oct 2016, 09:51 PM
  3. Stepper Motor drivers
    By KBs PensNmore in forum CNC Forum
    Last Post: 3rd Sep 2016, 02:07 AM
  4. DC stepper motors voltage??
    By KBs PensNmore in forum ELECTRICALS
    Last Post: 18th Aug 2016, 07:24 PM
