Results 1 to 3 of 3
    Nov 2019
    Canada
    14
    Default Hardware for Industrial-Grade CNC
    I have developed a prototype of a CNC Machine for my client, I now need to use industrial grade components, but I struggle with the hardware, I am confused.
    I just learned about PLC, and I don't know anything about them. What it takes to make an Industrial-Grade CNC ?
    Should I use a PLC for my CNC ? What PLC to use ? What modules ? What is the hardware configuration ?
    I want to learn, But I struggle to find informations for this on the web. Do you have some documentations ?
    I need your help, I am a little bit lost I have to admit.
    Thanks !
    34
    1,080
    It seems very strange to me that you would design a prototype of a machine that you have no idea how to build or what to build it with...
    If it needs to be industrial grade, I strongly recommend that you go out and find an existing industrial machine that will do what you need. This is not like Lego where you can simply stick a bunch of off-the-shelf components together, plug them in and expect it to just work.
    It sounds like you're in way over your head already, I suggest you back away from this project now before you end up in a very deep and expensive hole with no way out.
    Mar 2014
    South of Adelaide
    1,227
    what sort of machine? lathe? Mill? the Control for most industrial CNC (FAGOR, Fanuc, etc) is about $20000, then add servos from there. PLC only works for simple stuff.
  1. Chest Hardware
    By Luke Maddux in forum THE SMITHY
    Last Post: 22nd May 2015, 02:56 PM
  2. Handmade Hardware
    By Luke Maddux in forum METALWORK GENERAL
    Last Post: 4th May 2015, 07:12 PM
  3. new hardware chain
    By azzrock in forum METALWORK GENERAL
    Last Post: 13th Sep 2011, 11:21 PM
