Results 1 to 3 of 3
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,102
    Default WHo here has a CNC mill (not router) with a 350mm diameter envelope?
    Hi all. does anyone here have a CNC mill that could do an irregular shape that fits into a 350mm diameter piece of 6061 aluminium, 35mm thick?
    I believe that all machining can be done from one side, although there will be some holes to be at least spotted or drilled accurately on the opposite face.
    If so, would you be interested in making a one-off for me some time?
    What files would you need and would that cost me?
    Cheers, Joe
    Nov 2012
    Mid North Coast NSW
    422
    Just curious.
    Can you show a picture of the item you need machining ?
    Aug 2010
    72
    3,102
    Haha.... The item doesn't exist yet! Nor do any drawings.i have a project in mind that I'm researching solutions to before investing too much time and money in before I know how to make it happen.
    It's a joining housing/ ring to connect two engines together....
    Joe
    Cheers, Joe
  1. Small diameter plastic oil lines on mill - what sort of tube?
    By OxxAndBert in forum METALWORK GENERAL
    Last Post: 30th Mar 2020, 08:41 AM
  2. Replies: 1
    Last Post: 22nd Apr 2019, 07:35 PM
  3. Diameter Of A Circle
    By Keith_W in forum METALWORK GENERAL
    Last Post: 27th May 2014, 03:51 PM
  4. router bits in lathe to mill aluminium - youtube video
    Last Post: 29th Oct 2013, 06:55 PM
  5. minor diameter
    By tanii51 in forum THE HERCUS AREA
    Last Post: 26th May 2010, 10:55 PM
