Results 1 to 4 of 4
    Nov 2019
    Canada
    14
    Default Mach3 gcode work piece very very small
    Hello created Gcode in aspire 9.4 saved it and when I load it onto Mach3 the work piece that I want to cut is very very small and the z,x,y, axis sizes change to 3 to 4 meters when they were just about 100mm before loading the gcode please help I am really wanting to cut my first bit of work
    thank you
    Mar 2009
    54
    825
    I'm not familiar with Aspire but have you used the correct post processor for Mach3?
    Greg.
    Oct 2012
    Wallerawang NSW
    28
    Default Metric/Imperial setup
    It sounds to me that you may have the drawing done in either metric or imperial units and your machine is set for the opposite. I think you need either a G21 or G20 at the start of your GCode to set the correct units.
    Mar 2014
    South of Adelaide
    1,227
    please post the first 20 or so lines of your code. Without seeing what code you are feeding your machine it will be impossible for us to help you.
  1. Lathe chuck forcing work piece out???
    By nigelpearson in forum METALWORK GENERAL
    Last Post: 22nd May 2020, 05:35 PM
  2. Milling work needed on a piece of PFC
    By SurfinNev in forum METALWORK GENERAL
    Last Post: 1st Dec 2019, 08:11 PM
  3. Centec2A - a (small) piece of history
    By TheNutter in forum METALWORK GENERAL
    Last Post: 27th Oct 2014, 06:19 PM
  4. Interesting piece of maching work
    By Woodlee in forum METALWORK GENERAL
    Last Post: 19th Mar 2009, 10:17 AM
  5. Asking for someone to produce a piece of work - acceptable?
    By Manaz in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 7th Oct 2007, 06:48 PM
