Results 1 to 5 of 5
Thread: First Job off CNC Mill
27th Mar 2020, 09:16 AM #1Golden Member
- Apr 2009
- Kingswood
- 930
For all my fellow Forum Members that have been following progress on my mill, the first job is done.
I cut a clamp ring out of 12.4 mm aluminium plate to encircle the quill to mount a DTI to enable easy pick-up of a circular work piece.
First half was a 8 mm slot drill to full depth with job divided into 4 to allow changes in clamping at each step.
Second half was a 8 mm slot drill to 10 mm complete shape, then a 6 mm slot drill to miss the previous edge by 0.1 mm, and cut to full depth with triangular tabs included.
The second method will be the way I do future similar jobs.
John
27th Mar 2020, 07:59 PM #2
Hi John,
I assume that you have cracked the striations problem. I have to ask, but what happened to the piece at the bottom in the second picture.
Having said that, I do like the way you have mounted the test gauge for centring work.Best Regards:
28th Mar 2020, 08:28 AM #3Golden Member
- Apr 2009
- Kingswood
- 930
The striations have been put aside for the moment.
I decided to just use the machine to make some parts and see how I go.
For real components, striations are not visible.
The clamp ring was made as two identical parts, with one reversed (the lower one) for the assembly.
The lower half is the one I programmed to "full depth", which I missed by the thin web visible in the photo.
The web on the outside had been cleaned off before I decided to take a photo.
The upper half shows the remnants of the tabs which held the job to completion.
Once the hinge and threaded fitting were finished, the complete ring was held in a 4-jaw on the lathe for boring to size.
To check, I sat the chuck with job on the mill table, removed the two dogs from the NT30 spindle, and extended the quill into the job.
Have ordered neoprene rubber sheeting for protection and magnetic proximity switches for the limits.
Inductive proximity switches would have been preferable, but they were 10x the price.
These will keep me busy for a while.
John.
28th Mar 2020, 07:24 PM #4
Hi John,
Would the sensors that are supplied with the cheap tacho's work for you ? The ones with the little tell tale led on them.
Silicon rubber sheeting is widely used in the food and confectionery industry. There is a factory near here that pays to get rid of the stuff. I don't know where it ends up, but I did end up getting a roll of 3 mm thick white materiel, from the local scrap yard. I've used it a couple of times for protecting the mill bed and on the lathe and grinder.Best Regards:
30th Mar 2020, 09:14 AM #5
Am sure with use, many of the bugs will be ironed out.
If you can find it in my scrap section without taking up my work time, then you may get it for zip. If I have heaps of it of course.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
Hercus o mill Vertical mill head lubrication
By china eyes in forum THE HERCUS AREAReplies: 0Last Post: 14th Oct 2018, 06:57 AM -
Selecting a small Mill / Mill/Drill
By Wombat200 in forum METALWORK GENERALReplies: 31Last Post: 15th Mar 2012, 10:58 PM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM -
Face Mill V End Mill
By eskimo in forum METALWORK GENERALReplies: 8Last Post: 31st Aug 2010, 03:19 AM -
