Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Sep 2009
    Newcastle
    341
    Aluminium might be a good starter choice.
    A lot of DIY CNC people cut predominantly Alu and so there is a lot of info out there.
    Can we have some more pictures?
  2. #17
    Apr 2009
    Kingswood
    930
    Checked the gibs, they were certainly not as tight as originally setup.
    A bit of operation has settled them in.
    Reset the X and Y, the Z seemed as tight as one would want.
    Another problem arises, checking gib tightness with steppers attached is difficult.
    Any suggestions on how to do this ?
    Did another cut the same as the previous:
    - CI 18 mm deep,
    - 6-flute solid carbide,
    - 0.2 mm DOC,
    - climb milling,
    - 2500 RPM,
    - 500 mm/min.
    Striations are a bit reduced, but still visible.
    I hope the photo shows what I mean.
    Note that the striations are undetectable, they are visual only.
    John.
  3. #18
    Apr 2009
    Kingswood
    930
    Jogged the tool back at 40 mm/min with no cut set, got an absolute beautiful finish.
    Changed the steppers to 16 microsteps, 3200 steps per rotation.
    Operation seemed to be a bit quieter with less vibration, but that might be wishful thinking !
    Did a repeat cut as before.
    Got a reasonable finish with random vertical steps or grooves, and perhaps striations in the background.
    Not sure what I will try next.
    I think I will return to 10 microsteps as that was the machine when acquired.
    Then do some jobs and see how 'real world' jobs go.
    John.
  4. #19
    6,443
    Hi John,
    I think that you will find the greater the micro steps the finer the cut will be. However as the number of steps increase there is more chance of missing steps, which will get worse as the load on the cutter increases.
    Looking at that last picture, I would be quite happy with that finish, particularly in aluminium.
  1. Hercus o mill Vertical mill head lubrication
    By china eyes in forum THE HERCUS AREA
    Last Post: 14th Oct 2018, 06:57 AM
  2. Selecting a small Mill / Mill/Drill
    By Wombat200 in forum METALWORK GENERAL
    Last Post: 15th Mar 2012, 10:58 PM
  3. Arboga EM825 mill vs Hercus model 0 mill?
    Last Post: 14th May 2011, 03:16 PM
  4. Face Mill V End Mill
    Last Post: 31st Aug 2010, 03:19 AM
  5. No. 0 Mill Serial Number and Mill at Work Photos
    By Anorak Bob in forum THE HERCUS AREA
    Last Post: 30th Dec 2008, 03:31 AM
