Results 1 to 4 of 4
6th Mar 2020, 09:04 PM #1Novice
- Nov 2019
- Canada
- 14
How to identify die casting vs CNC?
Hello! How do you know if a product was made using CNC machining or die casting? Any inputs would be appreciated!
6th Mar 2020, 10:25 PM #2
Hi NGrimberg,
Careful examination !Best Regards:
7th Mar 2020, 07:06 AM #3Philomath in training
- 6,541
The surface roughness/ appearance will be different (machined surfaces should show as machined while die cast will be a slightly matt surface - a bit like 2000 grit wet and dry). Die castings should also show some draft, so the sides will not neccessarily be at 90 degrees to each other, or there will be a ridge where two drafted surfaces meet). Machined parts should be flat and square.
8th Mar 2020, 10:09 AM #4Gear expert in training
- 34
- 1,075
You may also see marks from the ejector pins on die castings like these
Casting Tools Part 5 - Casting a part
By RayG in forum THE FOUNDRYReplies: 10Last Post: 30th Jul 2018, 12:46 PM -
Can anyone identify this tool?
By John T K in forum ANTIQUE AND VINTAGE MACHINERYReplies: 5Last Post: 2nd Oct 2017, 11:37 AM -
Casting about for cast iron casting ideas
By Graziano in forum THE FOUNDRYReplies: 49Last Post: 1st Apr 2012, 12:05 PM -
Casting Tools Part 4 - Sand Casting Tools
By RayG in forum THE FOUNDRYReplies: 8Last Post: 9th Dec 2011, 12:03 PM
