Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    5,248
    I bought these 1m long x 25 mm wide tie straps with self clamping grippers on eBay for $1.50 each for another project that didn't go anywhere and decided to use them in this simple emery paper holder
    The metal frame is a piece of 25mm SHS Al cut to shape with the WW BS.
    I got SWMBO to sew the two straps together like this so the combo is a bit shorter than the Al frame and then cut the excess straps off.
    The emery can be reversed so the paper is either firm up against the Al as shown below, or with the paper hanging out in the breeze as shown in the first image.
    Think I might get some more tie straps and make up a couple of these.
  2. #17
    Charlestown NSW
    61
    1,222
    A story about lathes and emery.
    Years ago, when I worked in the power station, there was an incident in the machine shop. I did not witness this incident myself although I was familiar with the lathe and the part involved.
    One day one of the blokes (Stan) that worked in the machine shop, was using one of the bigger Colchesters ( I think it was a Mastiff 1800) and he had a S/S spacing sleeve from a pump in it. The sleeve was about 400mm maybe 500mm long ( this was around 1885 so my memory of exact sizes is a bit hazy now), about 200 maybe 250 ID with a internal keyway about 25mm wide X about 12 deep in it. Apparently the bore was slightly under size so he was trying to hone it out using some fine emery attached to a length of wood.
    Anyway during the process the emery or the wood got snagged in the keyway, pulled his hand and arm into the bore and the sharp edge of the bore and keyway sliced his arm off. As you can imagine it all happened pretty quickly, and it didn't slow the machine down at all.
    At the time I didn't realise it had actually taken his arm off (or almost off) It was only years later that there was a story on 60 minutes or one of those shows about the surgeon who reattached his arm and they interviewed Stan about what had happened and how he had been repaired.
    Scary stuff. I've never liked using emery on a lathe even though I will when I have to. So, so easy to get complacent and get caught.
    Peter
  3. #18
    May 2011
    Murray Bridge S Aust.
    67
    4,184
    Quote Originally Posted by bollie7 View Post
    The sleeve was about 400mm maybe 500mm long ( this was around 1885 so my memory of exact sizes is a bit hazy now), about 200 maybe 250 ID with a internal Peter
    Jeez Pete, when I last saw you you looked about 50, you hold your age well for someone who's about 150 years old!!!!!
    My memory would be a bit hazy too, if I was that age.
  4. #19
    Charlestown NSW
    61
    1,222
    I could easily say that that was a deliberate typo to see if anyone was on their toes, but that would be handling the truth extremely carelessly.
    In fact that was a seniors moment. A "way past my normal bed time" seniors moment in fact.
    Peter
  5. #20
    Aug 2019
    Sydney, Australia
    52
    51
    Wow. That is scary stuff. One would think having the emery at arm's length (on a wooden stick) would be safe enough!
    Doing anything like this (inside finishing, or on a very large lathe) is always going to be a danger. Need a longer stick, so you can stand several feet back?
    For outside polishing/reducing, I always tried to use a very fine file. e.g. a worn out old Sandvick.
    That way, you can hold it LIGHTLY at either end, well away from the job.
  6. #21
    Sep 2006
    Mallacoota,VIC,Australia
    49
    742
    No sticks with sandpaper on the lathe for me , just the thought is scary. I realise that a fair bit of development went into the sanding attachment on the Sponmech website, but the price is ridiculous.
    All The Best steran50 Stewart
  7. #22
    Jan 2004
    Mackay North Qld
    4,977
    This has been a good thread so I don't suppose there will be too many objections if I move it to the safety file.
  1. File & Emery
    Last Post: 24th Oct 2015, 09:35 PM
  2. Replies: 2
    Last Post: 15th Jul 2013, 01:24 AM
  3. SOLD: Lathe for Lathe Drill Mill (Near Liverpool NSW)
    By Auskart in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Jun 2010, 07:02 PM
  4. Buying a lathe (Old massive Lathe, or New small C6 Lathe)
    By Ch4iS in forum METALWORK GENERAL
    Last Post: 25th Mar 2009, 12:19 PM
