Results 1 to 3 of 3
Thread: Pallet Lifter Wheels
21st May 2023, 10:54 PM #1Most Valued Member
- 70
- 1,514
I have a 1000KG pallet lifter that I am restoring and it will need new wheels. Old were poly and cracked from age. Was considering nylon as it will be used on concrete. Front wheels are 80mm diameter and 70mm wide and I can get those in both poly or nylon probably. Rears are 200mm diameter and 50mm width but have not found them in nylon yet. Question is what would you choose, poly or nylon?
Nev.
21st May 2023, 11:38 PM #2Most Valued Member
I think Poly would be a better choice, from what I can understand poly wheels are better.
I have attached some details on the cast centred wheels, and some reading on which is better, nylon or poly.
https://www.richmondau.com/product-c...product-page=3
https://custompolyurethane.co.uk/pol...better-wheels/
HTH
21st May 2023, 11:53 PM #3Golden Member
- Apr 2019
- 596
I have just ordered some for mine but they are 180mm....https://www.aalstore.com.au/?s=Hand+...ct&dgwt_wcas=1
undercutter / bed lifter - how thick and which steel to use?
By potato in forum METALWORK GENERALReplies: 3Last Post: 5th Jun 2021, 10:08 PM -
Machining hubs and tyres for a pallet lifter
By SurfinNev in forum METALWORK GENERALReplies: 5Last Post: 1st May 2021, 10:37 PM -
Hydraulic Lifter Mod.
By SurfinNev in forum METALWORK PROJECTSReplies: 4Last Post: 26th Oct 2020, 07:06 PM -
Lathe motor lifter
By Poloris in forum METALWORK PROJECTSReplies: 1Last Post: 18th Jan 2016, 07:57 AM -
Electric Pallet lifter
By BobL in forum METALWORK GENERALReplies: 19Last Post: 29th Nov 2014, 06:22 PM
