Results 1 to 5 of 5
    Oct 2019
    Adelaide, SA
    1,223
    Default VR or Simulator machining? Someone actually thought of making it :)
    I never thought such a thing existed but why will anyone want to do machining in a simulator
    https://youtu.be/ydTLe4cHsck
    For $20 you get a big mill, with a kurt vice, unlimited endmills/drills, free coolant, unlimited supply of material, and most of all you do not need to clean the swarf
    Someone in the comments mentioned there is even a simulator lathe game
    Perhaps for students? Soon we will see educational institutes using this tech, maybe?
    May 2011
    Murray Bridge S Aust.
    5,959
    Probably the way of the future, for machinists and most other trades.
    At least there's no expensive machinery that the student can stuff up.
    I know maritime training have a Simulator, that a friend on here used to look after.
    Dr's have been doing similar for some time, I believe.
    Oct 2019
    Adelaide, SA
    1,223
    Similar to flight simulators, I can see the benefits but manual machining is about feel. They probably have something similar for welding
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    They do indeed use a virtual reality welder for training! It is VERY realistic, sound and all. I've used one at an engineering exhibition once and it was amazing! No gas wasted, no burns possible, no wasting metal or wire.... I think it would be as good as actual welding for odd setups and complex position combinations on expensive parts - before you stuff up a real part.
    Cheers, Joe
    May 2011
    5,959
    Thanks Joe for reminding me, I was watching You Tube on making harvesters.
    When they come up with a new design, they actually have a virtual robot welding machine, to check that it's possible to be able to weld where required, so that the nozzle can be place at the required angles, locations etc, without fouling on any thing.
    I think it was in the John Deere factory.
  1. IMPORTANT Just a thought
    By colbra in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 10th Feb 2012, 04:20 PM
  2. i thought i had a windfall but?
    By tanii51 in forum METALWORK GENERAL
    Last Post: 28th May 2010, 08:57 AM
  3. I thought this may interest someone
    By matthew_g in forum METALWORK GENERAL
    Last Post: 14th Jul 2008, 02:16 PM
