Results 1 to 10 of 10
Thread: Another maths question
21st Dec 2022, 05:54 PM #1Most Valued Member
- 70
- 1,513
Three hole M8 mounting on a PCD of 142mm. What is the distance between the centre of one hole if you draw a line through the centre of the other two holes?
Hope that makes sense. With rough measurements I get 107mm.Nev.
21st Dec 2022, 06:19 PM #2
Easy to do in CAD but I am several hours from a computer at the moment.
21st Dec 2022, 06:26 PM #3Most Valued Member
- 70
- 1,513
I got my measurement by screwing three 8mm bolts into the holes, them placing a straight edge against the inside of two of the bolts and measuring from the outside of the third bolt, to the outside of the straight edge. Probably good enough, but want it as close to perfect as I can get.
Nev.
21st Dec 2022, 06:40 PM #4Most Valued Member
- 70
- 1,513
Would also like the centre to centre distance between two holes. I get roughly 123mm.
Nev.
21st Dec 2022, 06:54 PM #5Senior Member
- Melbourne, Australia
- 129
21st Dec 2022, 07:52 PM #6Philomath in training
21st Dec 2022, 08:15 PM #7Most Valued Member
- 70
- 1,513
Thank you to all.
Nev.
21st Dec 2022, 09:24 PM #8Most Valued Member
Hi Nev, should you ever need something like this again, there is a posting at the bottom of the Forum with practically everything that you'll ever need, just a matter of searching through the listing.
Have put a link to it below. I use it VERY often.
https://metalworkforums.com/f218/t20...or-practically
Hope this helps with future mathematical questyuns.
23rd Dec 2022, 09:55 PM #9Most Valued Member
- 70
- 1,513
Found some good info when working with PCDs here -
https://learnmoredeeply.com/what-is-...adjacent-holesNev.
24th Dec 2022, 11:32 AM #10Senior Member
- Apr 2018
- 168
Went through all this when sorting out rims when clearing out fathers house.
https://www.mwsint.com/site/cms/contentviewarticle.asp?article=661
A little maths help
By Stustoys in forum GENERAL DISCUSSION / OFF TOPICReplies: 15Last Post: 28th Oct 2022, 04:52 PM -
Maths help re levels and calibration
By bollie7 in forum METALWORK GENERALReplies: 18Last Post: 30th Apr 2020, 09:04 PM -
A question?
By th62 in forum METALWORK GENERALReplies: 4Last Post: 23rd May 2013, 11:33 AM -
AL 960 Question
By Lindsalso in forum METALWORK GENERALReplies: 14Last Post: 5th Apr 2012, 05:04 PM
